See how to find a small oil leak #3227742
04/17/24 04:39 PM
04/17/24 04:39 PM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
Plug off your breathers and dipstick. Mine has a vacuum pump so no breathers to worry about. The dipstick is O ringed so it seals. Grab yourself a handy dandy Harbor Frieght regulator. This one was $7. Attach the hose to the valve cover at about 5 psi. Spray away with the soapy water. When the trans was pulled for service there was a little oil at the bottom. Just a few drops at the bottom of the bell housing. Once the trans was out everything looked dry. As always this method finds any leak.
Doug
Screenshot_20240417_162539_Photos.jpgScreenshot_20240417_162233_Gallery.jpg20240417_161809.jpg
Re: See how to find a small oil leak [Re: dvw] #3227744
04/17/24 05:12 PM
04/17/24 05:12 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Sweet. I always put some ultra gray around the plug just for extra measure.
Re: See how to find a small oil leak [Re: dvw] #3227745
04/17/24 05:13 PM
04/17/24 05:13 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Very clever idea.
It's a good idea to use a sealer around cam plugs I think. Most people don't do it that I've noticed, but the sealing contact surface on those is so narrow it makes me think twice about them. The last engine I built I took my finger and smeared some sealant around it after the plug was installed anyways just in case.
Re: See how to find a small oil leak [Re: dvw] #3227757
04/17/24 06:05 PM
04/17/24 06:05 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
Thanks Doug , we all love cheap & easy . Gary
Re: See how to find a small oil leak [Re: Gabby63] #3227822
04/18/24 06:26 AM
04/18/24 06:26 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Cool tip, ever since I had one of those plugs fall out I smear them heavily with RTV, then I remember it can't be seen and I smear a little more.
When I lost one of those from my 360 it only leaked under heavy acceleration. Just driving or idling it didn't leak. Hammer down and you got a bellhousing full of oil.
68 Barracuda Formula S 340
Re: See how to find a small oil leak [Re: Neil] #3227829
04/18/24 07:32 AM
04/18/24 07:32 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I learned from day one - Indian Head Gasket Shellac on freeze plugs - Then I back that up with a bead of grey Permatex
Re: See how to find a small oil leak [Re: DoubleD] #3227850
04/18/24 09:42 AM
04/18/24 09:42 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Conversely, you'll find a crankcase leak with sight, sound, and possibly smell and feel (ouch) if you don't trouble using a regulator?
Re: See how to find a small oil leak [Re: DoubleD] #3227851
04/18/24 09:43 AM
04/18/24 09:43 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Green wicking Loctite too!
Re: See how to find a small oil leak [Re: HardcoreB] #3227857
04/18/24 10:37 AM
04/18/24 10:37 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Great idea.
Rich H.
Esse Quam Videri
Re: See how to find a small oil leak [Re: ZIPPY] #3227906
04/18/24 02:12 PM
04/18/24 02:12 PM
PA
moparacer Offline
moparacer  Offline
PA
I use Ultra grey on that. Some on it when it goes in, and a coating around outside to be sure.
A leak there would be about as fun as a rear main seal leak.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: See how to find a small oil leak [Re: moparacer] #3227908
04/18/24 02:19 PM
04/18/24 02:19 PM
Tulsa, Oklahoma
340Cuda Online content
340Cuda  Online Content
Tulsa, Oklahoma
I have one of these cheap smoke machines from Amazon.
I have found it invaluable in sealing up a race engine to pull a good vacuum with a pump.
https://www.amazon.com/AutoLine-Pro-Automotive-Diagnostic-SMK-1/dp/B06XHRBKTM?th=1
Re: See how to find a small oil leak [Re: 340Cuda] #3228013
04/19/24 07:36 AM
04/19/24 07:36 AM
MI, usa
dvw Offline OP
dvw  Offline OP
MI, usa
It was installed with Ultra-Grey. I was just to stingy. It has enough now.
Doug
