Re: Milodon external oiling pump
[Re: Z_Z]
#3227632
04/17/24 09:27 AM
04/17/24 09:27 AM
Posts: 2,677 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Chewed up pump gears is fine. Nothing is timed. Just clean everything up good and put it back together. Don't get in a hurry.
2011 Drag Pak Challenger
[Re: Cab_Burge]
#3227748
04/17/24 05:22 PM
04/17/24 05:22 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have a Milodon high volume pump, and found it to be at max spec out of rhe box! .004 end clearance, on a product that will grow out of spec (max end clearance .004) just because the aluminum housing will grow as it warms. I used a flat plate and sandpaper to bring it down to .0017, or .0002 over minimum cold. That ought to help it pull a prime now. This was not in your original post, but felt it important.
