Crane BB rockers with 0.300 offset? #3227576
04/16/24 09:11 PM
04/16/24 09:11 PM
AndyF Offline OP
AndyF  Offline OP
I have a couple of pairs of new Crane rocker arms that I was going to sell, but now I have no idea what they fit. The offset is about 0.300 inches which is more than stock, but much less than Victor or Indy heads. I thought maybe Stage V or VI but it doesn't appear to be the same. Maybe B1-BS or something like that? Anyone know what uses a 0.300 offset rocker arm?
Re: Crane BB rockers with 0.300 offset? [Re: AndyF] #3227590
04/16/24 11:04 PM
04/16/24 11:04 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
According to this they fit stage 4,5,6 and Indy sr
https://www.summitracing.com/parts/CRN-64765L-1
Re: Crane BB rockers with 0.300 offset? [Re: GomangoCuda] #3227596
04/17/24 12:20 AM
04/17/24 12:20 AM
AndyF Offline OP
AndyF  Offline OP
Cool deal. I never thought to check Summit since Crane has been gone so long. Looks like my measurement was close, they spec them at 0.290 offset and I guess it is only for the intakes. Thanks, I'll update my information. Maybe there is someone out there that needs a spare or two.
Re: Crane BB rockers with 0.300 offset? [Re: AndyF] #3227621
04/17/24 08:37 AM
04/17/24 08:37 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
they're intake only and right and lefts.
Re: Crane BB rockers with 0.300 offset? [Re: AndyF] #3227629
04/17/24 09:21 AM
04/17/24 09:21 AM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
When MP used to sell the blue versions, they were listed for Stag IV / V heads. They were nice because you could run this style in the 1.6 ratio and the additional offset meant you didn't have to worry about pushrod clearance with OEM iron heads.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Crane BB rockers with 0.300 offset? [Re: Brad_Haak] #3227675
04/17/24 11:40 AM
04/17/24 11:40 AM
AndyF Offline OP
AndyF  Offline OP
I never knew about that trick
Re: Crane BB rockers with 0.300 offset? [Re: AndyF] #3227685
04/17/24 12:17 PM
04/17/24 12:17 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I have a set on a rpm headed 440 for that reason in 1.6 ratio. They are ported pretty good and didn't want to chance it
