Air Pressure Gauge #3227423
04/16/24 11:21 AM
04/16/24 11:21 AM
E
earlymopar Offline OP
E
I'm looking for a good and reasonably accurate tire pressure gauge that's not going to break the bank and will last more than a year. Purely mechanical or electronic. What are all you using that you like?
Re: Air Pressure Gauge [Re: earlymopar] #3227436
04/16/24 12:27 PM
04/16/24 12:27 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Think mine is just a MOROSO mechanical gauge...( I forget... but it is just a big Dial face gauge) Not a fan of the digital... Never needed to replace a battery on a mechanical gauge.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Air Pressure Gauge [Re: earlymopar] #3227450
04/16/24 01:19 PM
04/16/24 01:19 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Got a gauge made by Allstar, works great, had it for years.
Lane Automotive( motor state) sells it
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Air Pressure Gauge [Re: W.I.N. Racing] #3227457
04/16/24 01:32 PM
04/16/24 01:32 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
x2, I've had the Moroso one forever and have been happy with it. The rubber protective case is starting to crack some but it's also easily 25 years old at this point.
Re: Air Pressure Gauge [Re: Blusmbl] #3227465
04/16/24 01:58 PM
04/16/24 01:58 PM
moparx Offline
moparx  Offline
i have been using a round dial gauge that has the letter M inside a red oblong circle.
it says : "precision" and Made in U.S.A. on the face which is black with white letters and pointer. it reads in .5 lb increments to 60lbs, but i don't think the .5lb scale would be particularly accurate, considering the 2"[or so] dial face and the 60lb range.
i bought several of these at the speed shop on main street way back in the mid 70's.
got three or four for me, and one each for my brother and old man. they came with a rubber "bootie" you could install or not.
all of the ones i own show the same reading on whatever tire i check, so at least they may have been calibrated using the same method when built.
beer
Re: Air Pressure Gauge [Re: earlymopar] #3227476
04/16/24 02:18 PM
04/16/24 02:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I use an Intercomp digital these days. But I have two large face Moroso gauges as well.. None of those are exactly budget friendly. I have a couple friends who like their long acre ones.
Re: Air Pressure Gauge [Re: Al_Alguire] #3227507
04/16/24 04:18 PM
04/16/24 04:18 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I use a Dwyer DPGA-05 it's a 0-15 PSI and reads to .01 of a lb. It's accurate but it's not super cheap, around $130 for just the gage. I used an old whip from a cheap gage that lasted a year or so. I had this one around 7 years and it makes the trip every time I go down the track.
Without Data, you’re just another guy with an opinion.
Re: Air Pressure Gauge [Re: earlymopar] #3227518
04/16/24 04:51 PM
04/16/24 04:51 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I still have the large-face 0-15 PSI Moroso I bought 25 years ago, but the problem is everything I run now are radials which require higher pressures
I picked up one of these quite a while ago: https://www.jegs.com/i/JEGS/555/65035/10002/-1 and found it to be very accurate, considering I cross-checked it against two other gauges across a range of pressures and they were surprisingly consistent
The only issue was I dropped it once pretty hard and it lost its mind. I purchased another one, only this time I also got the Jeg's extended warranty for 3 years which is a simple "if it's broke, they replace it" deal for another $14; just checked and it's good for another 2 years
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Air Pressure Gauge [Re: Brad_Haak] #3227535
04/16/24 06:17 PM
04/16/24 06:17 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
My setup for track days was just a 8 dollar air chuck, a 1/4"npt tee, a couple of 1/4 nipples, a ball valve and a Winters guage. It cost like 40 bucks to put together. I was using a 0-30 gauge, but you can plug in whatever range you want.
Re: Air Pressure Gauge [Re: earlymopar] #3227618
04/17/24 08:03 AM
04/17/24 08:03 AM
E
E
Thanks for all of the feedback. Lots of good examples.
I have one of the mechanical gauges encased in rubber that I really have liked using. Its accurate and durable and has peak pressure plus tire tread depth gauge. The only problem is that it just started leaking pressure (won't maintain the peak pressure reading so I assume the button that releases the peak pressure is leaking). I might try placing a bit of rubber seal lubricant around the release button to see if that might help. If not, I did find an Earl's gauge set up in my brother's stuff that has bleeder and fill valves that may work as a replacement.
Thanks again.
Re: Air Pressure Gauge [Re: earlymopar] #3227690
04/17/24 12:30 PM
04/17/24 12:30 PM
moparx Offline
moparx  Offline
whatever you do, don't lend out the gauge you decide on and really like, to "just anyone". it will surly come back screwed up, or just grow legs and hike away.
keep a dollar store or wally world cheapy for lending............
i'm going to guess i'm not the only one with this policy.
beer
Re: Air Pressure Gauge [Re: moparx] #3227732
04/17/24 03:45 PM
04/17/24 03:45 PM
Cab_Burge Online work
Cab_Burge  Online Work
I've had more than one low pressure good quality low air pressure gauge with the bleeder valves get ruin by loaning it out at the track, don't do that down tsk
You can offer to check their tires for them instead of loaning it out work shruggy
Re: Air Pressure Gauge [Re: Cab_Burge] #3227754
04/17/24 05:40 PM
04/17/24 05:40 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I like my joes racing glow in the dark face gauge up
Re: Air Pressure Gauge [Re: earlymopar] #3227819
04/18/24 06:06 AM
04/18/24 06:06 AM
Lexington NC
twinscrew698 Offline
Lexington NC
Had this for 30 Plus years but was alot cheaper back then.
https://www.summitracing.com/parts/mli-s-516
Still have it and works fine.
Re: Air Pressure Gauge [Re: twinscrew698] #3227827
04/18/24 07:15 AM
04/18/24 07:15 AM
E
E
Agreed on the loaning of tools. I always try to help but by using my tools myself if at all possible.
Good suggestion TW698. I always liked that mechanical "blade" style of pressure gauge.
Re: Air Pressure Gauge [Re: earlymopar] #3228841
04/23/24 09:22 PM
04/23/24 09:22 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
napa 90379 0-20 lbs $10 find your pressure that's works best for car, then monitor with gauge, who cares if it reads 15.5 pounds and is really 16, save $30-$100
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Air Pressure Gauge [Re: 440lebaron] #3228917
04/24/24 11:46 AM
04/24/24 11:46 AM
moparx Offline
moparx  Offline
this advice right here. ^^^^^^^^^^ iagree
as almost no one "calibrates" their air pressure gauges, a quality gauge that repeats constantly will work perfectly well. pick what pressure works the best FOR YOU, then use the gauge you like and use it ONLY. the same deal applies to not lend out the gauge you use on YOUR vehicle.
beer
Re: Air Pressure Gauge [Re: moparx] #3228937
04/24/24 12:44 PM
04/24/24 12:44 PM
PA
moparacer Offline
moparacer  Offline
PA
I have always used Longacre tire pressure gauges.
Always check yours with a known good one to start every year.
I have a friend that races go carts, check mine to his big $$$ gauge that is calibrated yearly. They are super picky about tire pressures.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Air Pressure Gauge [Re: moparacer] #3228946
04/24/24 01:31 PM
04/24/24 01:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Whatever gauge you use, and I'll admit this is near the edge of paranoia:
Use the same gauge for your race tires every time, as long as it's working reliably, of course.
As for lending ? I don't recall problems, but typically the tools I take to the track are the second-string stuff.
The thinking being that the car should be Right before you go, with only tweaking or maybe an emergency repair on-site.
That said, back in the Vintage TransAm days, we loaded damn near everything in the trailer - on those deals, you might be doing a lot more work.
