Re: Air Pressure Gauge
[Re: earlymopar]
#3227436
04/16/24 12:27 PM
04/16/24 12:27 PM
Posts: 2,117 Byron, NY
W.I.N. Racing
Byron, NY
Think mine is just a MOROSO mechanical gauge...( I forget... but it is just a big Dial face gauge) Not a fan of the digital... Never needed to replace a battery on a mechanical gauge.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: earlymopar]
#3227450
04/16/24 01:19 PM
04/16/24 01:19 PM
Posts: 11,724 Portage,michigan
B3422W5
Portage,michigan
I'm looking for a good and reasonably accurate tire pressure gauge that's not going to break the bank and will last more than a year. Purely mechanical or electronic. What are all you using that you like? Got a gauge made by Allstar, works great, had it for years. Lane Automotive( motor state) sells it
[Re: W.I.N. Racing]
#3227457
04/16/24 01:32 PM
04/16/24 01:32 PM
Posts: 8,182 Plymouth, MI
Blusmbl
Plymouth, MI
Think mine is just a MOROSO mechanical gauge...( I forget... but it is just a big Dial face gauge) Not a fan of the digital... Never needed to replace a battery on a mechanical gauge. x2, I've had the Moroso one forever and have been happy with it. The rubber protective case is starting to crack some but it's also easily 25 years old at this point.
[Re: Blusmbl]
#3227465
04/16/24 01:58 PM
04/16/24 01:58 PM
Posts: 19,562 north of coder
moparx
i have been using a round dial gauge that has the letter M inside a red oblong circle. it says : "precision" and Made in U.S.A. on the face which is black with white letters and pointer. it reads in .5 lb increments to 60lbs, but i don't think the .5lb scale would be particularly accurate, considering the 2"[or so] dial face and the 60lb range. i bought several of these at the speed shop on main street way back in the mid 70's. got three or four for me, and one each for my brother and old man. they came with a rubber "bootie" you could install or not. all of the ones i own show the same reading on whatever tire i check, so at least they may have been calibrated using the same method when built.
[Re: earlymopar]
#3227476
04/16/24 02:18 PM
04/16/24 02:18 PM
Posts: 19,380 Las Vegas
Al_Alguire
Las Vegas
I use an Intercomp digital these days. But I have two large face Moroso gauges as well.. None of those are exactly budget friendly. I have a couple friends who like their long acre ones.
[Re: Al_Alguire]
#3227507
04/16/24 04:18 PM
04/16/24 04:18 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I use a Dwyer DPGA-05 it's a 0-15 PSI and reads to .01 of a lb. It's accurate but it's not super cheap, around $130 for just the gage. I used an old whip from a cheap gage that lasted a year or so. I had this one around 7 years and it makes the trip every time I go down the track.
Without Data, you’re just another guy with an opinion.
[Re: earlymopar]
#3227518
04/16/24 04:51 PM
04/16/24 04:51 PM
Posts: 1,151 Loudoun County, VA
Brad_Haak
Loudoun County, VA
I still have the large-face 0-15 PSI Moroso I bought 25 years ago, but the problem is everything I run now are radials which require higher pressures I picked up one of these quite a while ago: https://www.jegs.com/i/JEGS/555/65035/10002/-1 and found it to be very accurate, considering I cross-checked it against two other gauges across a range of pressures and they were surprisingly consistent The only issue was I dropped it once pretty hard and it lost its mind. I purchased another one, only this time I also got the Jeg's extended warranty for 3 years which is a simple "if it's broke, they replace it" deal for another $14; just checked and it's good for another 2 years
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: earlymopar]
#3227690
04/17/24 12:30 PM
04/17/24 12:30 PM
moparx
whatever you do, don't lend out the gauge you decide on and really like, to "just anyone". it will surly come back screwed up, or just grow legs and hike away. keep a dollar store or wally world cheapy for lending............ i'm going to guess i'm not the only one with this policy.
[Re: earlymopar]
#3228841
04/23/24 09:22 PM
04/23/24 09:22 PM
Posts: 1,610 westerly, ri. usa
440lebaron
westerly, ri. usa
napa 90379 0-20 lbs $10 find your pressure that's works best for car, then monitor with gauge, who cares if it reads 15.5 pounds and is really 16, save $30-$100
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: moparx]
#3228937
04/24/24 12:44 PM
04/24/24 12:44 PM
Posts: 2,521 PA
moparacer
PA
I have always used Longacre tire pressure gauges.
Always check yours with a known good one to start every year.
I have a friend that races go carts, check mine to his big $$$ gauge that is calibrated yearly. They are super picky about tire pressures.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#3228946
04/24/24 01:31 PM
04/24/24 01:31 PM
Posts: 20,865 A collage of whims
topside
A collage of whims
Whatever gauge you use, and I'll admit this is near the edge of paranoia: Use the same gauge for your race tires every time, as long as it's working reliably, of course. As for lending ? I don't recall problems, but typically the tools I take to the track are the second-string stuff. The thinking being that the car should be Right before you go, with only tweaking or maybe an emergency repair on-site. That said, back in the Vintage TransAm days, we loaded damn near everything in the trailer - on those deals, you might be doing a lot more work.
