Re: Spraybar oiling and vaccum pump oops.
[Re: 4404dart]
#322733
05/19/09 04:05 PM
05/19/09 04:05 PM
Posts: 2,926 A shed in England
Tig
A shed in England
Hmm Not sure if the fitting position is the culprit here, our's has been there for 2 seasons no probs. There should be no "flow" through there once vacuum is achieved. Unless you got a gasket leaking. I'd check the spray bar holes, make sure they're not blocked. Check the rocker arm for cracks too, around the adjuster area. A buddy had one go after scorching a pushrod end. We figured it may have been the adjuster expanding with the heat.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#322734
05/19/09 04:21 PM
05/19/09 04:21 PM
Posts: 1,283 Colorado,U.S.A
4404dart
Colorado,U.S.A
I have to put on my spare pair of rockers, so I will check them. This is all we could come up with, and figured since this pair,mostly the exhaust were the only ones that didn't have oil dripping from the retainers, and were right under the fitting for the pump? I cleaned the tubes, and checked for oil when we primed it, and all was good. Maybe I'll open that hole up a little over this rocker? Thanks.
[Re: jamesc]
#322737
05/19/09 04:34 PM
05/19/09 04:34 PM
Tig
A shed in England
How much vacuum are you pulling? Should be no more than 12 in/hg BTW since it is said that the oil doesnt "aerate" enough with more on a wet sump, and wrist pins suffer (how wrist pin oiling changes with dry sumps I don't know ). Anyway, if you have a low reading you may have a leak, then you will have flow through the fitting and it will pull oil from that area. Do you have to empty oil from the breather? We get more water than oil through ours unless a gasket goes. HTH's
[Re: 4404dart]
#322743
05/19/09 08:30 PM
05/19/09 08:30 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The vac pump is moving air all the time(the rings arent a perfect seal). At least try a baffle over the port but thats not the best location for the port... try to locate it over the end of your short hold down shaft (where the stock shaft hold down would be... 2nd bolt back from the front) and it WILL need a baffle
