1968 Plymouth Valiant Pro Street Project
[Re: JonsGottaDusta]
#3226768
04/12/24 07:01 PM
04/12/24 07:01 PM
Posts: 324 Northport, al.
tvt59
Northport, al.
I have a 68' Valiant 2 door project that I've been working on for a few years. Lots of high dollar parts. I'm a motivated seller. I just need a sell it and move on. All responsible offers considered. PM me your questions and offers.
All metal replaced as needed. Most body work done. Hemi Denny Tubular front suspension, Freak Ride 4 link rear suspension. Quick Time SBM to T56 Magnum transmission bellhousing. Two disk clutch, hydraulic master cylinder and throw out bearing, New T 56 Magnum transmission, wilwood 6 piston front brakes and 4 piston rear brakes, areomotive 15 gallon stainless steel fuel cell with internal A1000 pump, new dr diff Dana 60, new aftermarket bucket seats, all new speed hut gauges, new dry nitrous system, the following can go with the car but the price will go up substantially, fresh 440" SBM W5 engine with 48 deg R3 block. Dyno'd 644 hp. Complete with all sensors and wiring harness Holley Dominator EFI system. Car is in Mobile, AL. Pm me and I can shoot you some pics
$ 10,000
Nothing worth anything comes easy. It is always harder to do the right thing.
My Grandfather
1970 Plymouth Duster 340
[Re: moparts]
#3230859
05/03/24 06:47 PM
05/03/24 06:47 PM
Posts: 551 ORANGE PARK,FL
gdmusclecar
ORANGE PARK,FL
70 PLYMOUTH DUSTER SHELL,FACTORY 340 CAR WITH VIN TAG,FENDER TAG IS NOT THERE,AND THERE IS NO TITLE,THERE WAS NO OPTION TO CLICK ON FOR NO TITLE,BUT YOU CAN GO THROUGH A TITLE COMPANY AND GET ONE,YES ITS MISSING LOTS OF PARTS,NO NOTHING ELSE IS INCLUDED,IT HAS RUST IN THE TRUNK LEDGE,MINOR RUST IN THE FLOORS,THE TRUNK PAN HAS SOME RUST,FRAMES ARE GOOD,IT HAS THE ORIGINAL 340 K MEMBER,DISC. BRAKES,FRONT SWAY BAR WITH POWER STEERING GEAR BOX,IT STILL HAS THE ORIGINAL EXHAUST TIPS,ITS JUST AS PICTURED.WE CAN HELP WITH LOADING IT. $1650.00
ORANGE PARK,FL.
EMAIL: GDMUSCLECARPARTS@YAHOO.COM
PH# 904-589-4645
69 PLYMOUTH BARRACUDA PRO STREET OR DRAG CAR
[Re: moparts]
#3230863
05/03/24 07:00 PM
05/03/24 07:00 PM
gdmusclecar
ORANGE PARK,FL
69 PLYMOUTH BARRACUDA FASTBACK,SOLID CAR,NOT A RUST BUCKET,SOMEONE STARTED TO BUILD A DRAG CAR OUT OF IT AT ONE TIME,THE ONLY THING WE DID WAS CUT THE CAGE OUT OF IT,NO ENGINE OR TRANSMISSION IT HAS A NARROWED 8-3/4 REAREND,IT HAS NEW DISC BRAKES ON THE FRONT,SOMEONE DID PUT HOME MADE REAR TUBS IN IT,AND THEY CUT THE REAR WHEEL WELL AROUND THE QUARTER PANEL,THEY KNEW NOTHING ABOUT BUILDING RACE CARS,THERE IS A CLEAR TITLE,DASH TAG AND FENDER TAG,SO YOU COULD MAKE A PROSTREET CAR,OR BUILD IT AS A DRAG CAR.
$5,000
THIS IS A SOLID TEXAS CAR.
ORANGE PARK,FL.
PH# 904-589-4645
