Page 2 of 3 1 2 3
Holley 4749 Carburetor Factory 383-440 [Re: Memongo] #3226651
04/12/24 07:30 AM
04/12/24 07:30 AM
Fenton, MI
Memongo Online rolleyes
Parts peddler
Memongo  Online Rolleyes
Parts peddler
Fenton, MI
Holley 4749 Carburetor Factory 383-440. Used, $125 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Call Steve 810-629-1097
Note: Came off a 70 383 Challenger
Factory Valve Cover Breather [Re: Memongo] #3226654
04/12/24 07:34 AM
04/12/24 07:34 AM
Fenton, MI
Parts peddler
Parts peddler
Fenton, MI
Factory Valve Cover Breather. Used, $15 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Valve Cover Oil Fill Caps [Re: Memongo] #3226655
04/12/24 07:35 AM
04/12/24 07:35 AM
Fenton, MI
Parts peddler
Parts peddler
Fenton, MI
Valve Cover Oil Fill Caps. Used, $10 Each + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
1. Not sure!
2. 73-74 model (came of my 73 Cuda)
3. Mopar Preformance Chrome New!
Note: Pick the one you want by photo 1-3
Oil Cap 2.jpg (743 downloads)
Oil Cap 3.jpg (742 downloads)
Oil Cap Chrome.jpg (742 downloads)
73-74 Electric Choke #3656730 All Models [Re: Memongo] #3226656
04/12/24 07:36 AM
04/12/24 07:36 AM
Fenton, MI
Parts peddler
Parts peddler
Fenton, MI
73-74 Electric Choke #3656730 All Models, Used, $30 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Fram CA160 Air Filter. New [Re: Memongo] #3226657
04/12/24 07:37 AM
04/12/24 07:37 AM
Fenton, MI
Parts peddler
Parts peddler
Fenton, MI
Fram CA160 Air Filter. New, $5 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Note: Used On Any 2bl Motor, See Photo 2 For Application!
Temperature Sending Unit / Oil Pressure Sending Unit [Re: Memongo] #3226658
04/12/24 07:38 AM
04/12/24 07:38 AM
Fenton, MI
Parts peddler
Parts peddler
Fenton, MI
63-76 Temperature Sending Switch #2426458 Used $7.50 + Shipping
62-80 Oil Pressure Sending Unit For Models With Warning Light. Used, $7.50 + Shipping.
Factory Carburetor 3.5 in" Stud With Wing Nut [Re: Memongo] #3226659
04/12/24 07:39 AM
04/12/24 07:39 AM
Fenton, MI
Parts peddler
Parts peddler
Fenton, MI
Factory Carburetor 3.5 in" Stud With Wing Nut. Used, $10 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Water Pump To Fan Spacer 1.25 in' Thick [Re: Memongo] #3226660
04/12/24 07:40 AM
04/12/24 07:40 AM
Fenton, MI
Parts peddler
Parts peddler
Fenton, MI
Water Pump To Fan Spacer 1.25 in' Thick. Used $15 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Fan Spacer 1.25 in.jpg (939 downloads)
Gates Single Belts.New [Re: Memongo] #3226662
04/12/24 07:41 AM
04/12/24 07:41 AM
Fenton, MI
Parts peddler
Parts peddler
Fenton, MI
Gates Single Belts.New, $10 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
1.Gates Belt 7470
2. Gates Belt 7490
3. Gates Belt 7580
Gates Belt 7470 .jpg (939 downloads)
Gates Belt 7490 .jpg (938 downloads)
Gates Belt 7580 .jpg (939 downloads)
Gates / Mopar Duel Alternator / Fan Belts.New [Re: Memongo] #3226663
04/12/24 07:42 AM
04/12/24 07:42 AM
Fenton, MI
Parts peddler
Parts peddler
Fenton, MI
Gates / Mopar Duel Alternator / Fan Belts.New, Price Below + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
1.Gates Duel Belt #7541 $20
2. Mopar Duel Belt #4106241 $25
Note: Pick the one you want by photo 1-2
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3227279
04/15/24 11:01 PM
04/15/24 11:01 PM
IL
furious70 Offline
furious70  Offline
IL
1969 440 HP block WS23L9G175918 or WS27L9G175918
You can see it is missing the body character in the stamping.
If you have one of those cars I could trade you parts if you wanted to reunite car and block.
Been in dry storage for many years. .030 and has 1 sleeve. $500 obo for block, caps, crank. Plus shipping if that is something you'd be interested in. Available in 52205 or 60188.
More photos available
70 Sport Fury
68 Charger
69 Coronet
72 RR
Big Block Main Bearing Caps - Used [Re: 71duster414] #3227562
04/16/24 07:47 PM
04/16/24 07:47 PM
CT
Rocket Offline
Rocket  Offline
CT
I have two sets and 4 spare BBM used main cap sets for the 2.75" crank journal. See pictures below.
$50 a set or $80 for the whole lot shipped in the lower 48 states. I will ship elsewhere for the added shipping cost.
Email me at procketrichard@hotmail.com with any questions or for more pictures.
BBM Caps 1.JPG (769 downloads)
BBM Caps 3.JPG (764 downloads)
BBM Caps 4.JPG (765 downloads)
BBM Caps 2.JPG (765 downloads)
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3227738
04/17/24 04:23 PM
04/17/24 04:23 PM
Nashville, TN
Rustymuscle Offline
Mopar Connection Magazine
Rustymuscle  Offline
Nashville, TN
The 505ci that I’m selling is a pretty extensive build that produces a peak horsepower of 631@ 5,500rpm and 659lbs. ft. of torque at 4,500rpm all on 93 octane gas pumped from a Shell gas station down the street.
You’ll receive the full dyno report if you purchase it.
The parts list is as follows:
Chrysler RB440 engine block (7/8/1977) bored 0.030” over
K1 Technologies 4.25” stroke crank, 8-bolt Hemi flange
K1 Technologies 7.100” H-beam connecting rods
MAHLE Power Pak flat top pistons (11.7:1 compression, 0.025” in the hole)
MAHLE rings
Clevite bearings
SB Concepts billet main caps
SB Concepts billet steel girdle
ARP main studs
ARP cylinder head bolts
ARP intake manifold bolts
Mancini billet aluminum rear main seal
Milodon High Pressure Oil Pump
Milodon 3/8” pick up tube
Milodon 7qt. low profile pan
Trick Flow PowerPort Top End Engine Kit:
• Trick Flow PowerPort 240 aluminum cylinder heads (78cc chambers)
• Trick Flow Track Heat square bore 4150 single plane intake manifold
• Trick Flow dual valve springs
• Harland Sharpe roller rockers & shafts
• Howard Cams hydraulic roller lifters
• COMP Cams push rods
• Trick Flow hydraulic roller camshaft (243 int./247 exh. @ .050” lift, 0.640 int./0.640 exh.)
COMP Cams bronze gear oil pump driveshaft
COMP Cams double roller timing chain
Milodon bronze gear intermediate shaft
PRW baffled, aluminum valve covers
440 Source hydraulic damper
440 Source crank & water pump pulley
Mancini aluminum water pump & housing
Mancini stamped valley pan
440 Source valley pan retainers & hardware
*This does not include carburetor, ignition (distributor, plugs or wires), or exhaust. Long block only.
Just by the parts list and machine work is a $16,800 engine, but I’m asking $14,500 or best offer.
email me directly at charged1969@hotmail.com
Mopar Connection Magazine, your source for daily news, real-world tech, features and much more.
Got a comment, question, or a story? Email me at kevin.shaw@shawgroupmedia.com
Re: For Sale - Big Block Engine - 2nd Quarter [Re: Rustymuscle] #3228285
04/20/24 02:07 PM
04/20/24 02:07 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
Brand New in the box Big Block Chrysler/Mopar Pro-Flo XT EFI Part # 7144 Manifold
Designed for 413-440 Chrysler motors, the Pro-Flo XT Chrysler 440 EFI intake manifold is engineered with a large plenum and long tapered runners to deliver maximum horsepower. This manifold delivers a broad torque band throughout the rpm range of 1500-7000 rpm. $450 + shipping PM here or Phone (716) 655-0625 this is a land line. Ask for Gary This manifold sell for $668 at Jegs and Summit
Re: For Sale - Big Block Engine - 2nd Quarter [Re: RalleyA12] #3228290
04/20/24 02:14 PM
04/20/24 02:14 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
SMR transmissions B/RB to small block transmission adapter kit. Part number SM 99-100P for a 6 bolt crank. New in box, the box has been opened but only for inspection, never installed the kit. for info: https://smrtrans.tripod.com/smrtransmissionsintro/id9.html $400 + shipping. PM here or phone (716) 655-0625 ask for Gary or leave a message ( this is a land line)
516 heads [Re: moparts] #3228820
04/23/24 07:59 PM
04/23/24 07:59 PM
MD
44T4speed Offline
44T4speed  Offline
MD
For sale - 516 heads that have been in my basement work room for a 5+ years - they came (just as you see in the pics) along with an engine block I purchased that I needed for a resto. - looks like a rebuild/refresh was done.
Rather not ship - I'm in MD - happy to travel a few hours to meet.
$200 - shoot me a PM
Just re - joined Moparts - Hi All..
440 cast crank [Re: moparts] #3228832
04/23/24 08:39 PM
04/23/24 08:39 PM
MD
44T4speed Offline
44T4speed  Offline
MD
For sale - 70's 440 cast crank - stored in same basement as the heads I posted - some rust but maybe savable - quick measurement on journals - all 2.375
$100 - PM if interested
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3229121
04/25/24 12:52 PM
04/25/24 12:52 PM
NY
ChargerCrazed Offline
NY
1967 Carter 383 Carburetor 4298S
Used, Original 1967 Carter 4298S (A7 = Jan. 1967) Carb, for 383 engine with manual transmission.
Needs to be restored. Missing a few bolts & secondary throttle shaft/plate assembly.
Asking $75 shipped in US.
If interested or need more pictures, send email: chargercrazed@usa.com
NOS Mopar Fan Clutch 2863264 [Re: moparts] #3229514
04/27/24 02:57 PM
04/27/24 02:57 PM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
Application is listed in 70-71 Parts Catalog as for 383/440 with a/c and 2.71/2.76 axle, 6" diameter, B/J/P/D/C vehicles
Has always been properly stored in box face down
$150.00 + shipping from 08724 NJ
Re: Weiand 7511 'B' engine intake [Re: ProStock1320] #3232427
05/12/24 10:40 PM
05/12/24 10:40 PM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
Found this in the back of a garage we were cleaning out for a widow. This is the early version of the Team G. 4150 square bore carb flange. Could stand a cycle in the dishwasher (while the wifey is gone of course). $100 as is, $250 if you want it cleaned, both + shipping. PayPal FF or postal money order. PM me here please.
Page 2 of 3 1 2 3
