Page 1 of 3 1 2 3
For Sale - Big Block Engine - 2nd Quarter #3223972
03/31/24 12:10 PM
03/31/24 12:10 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: Carter #9410s AFB Carbs 400 CFM (2) [Re: 19Coronet66] #3224013
03/31/24 02:36 PM
03/31/24 02:36 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
Pete Jackson Noisy Gear Drive – less than 500 miles $75
Big block water pump housing powder coated $50
Big block timing cover powder coated $25
Big block timing cover chrome $15
Factory chrome valve covers $35
Proform or similar chrome valve covers $20
Taylor spiro-pro plug wires big block Mopar $40
Miscellaneous Jegs hose and fittings $50
Mopar performance electronic distributor $80
Mancini Big Block Balancer MRE80013 – new $90 - SOLD
Parts located in Ripley, WV
Price doesnt include shipping
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3224118
03/31/24 09:02 PM
03/31/24 09:02 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
New factory type big block spark plug wire separator kit. Some surface rust from humidity on a couple of them. $50
NOS big block heat riser kit #3420046. $225
Two new, unused big block head pipe to exhaust manifold flanges still in the packages. $15 for the pair.
Unused/unopened big block exhaust manifold stud kit. Although the bag is unopened, I can see some surface rust from humidity on some of the pieces. $40
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
NOS Cal Custom polished big block valve covers. $450
New exhaust manifold heat stove to air cleaner hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
New big block chrome valley pan hold down rails & bolts. $30
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Single nipple oil breather with hose. $30
New Mopar Performance chrome big block distributor hold down. $20
New 12" long oval 4 barrel aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $55
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
NOS Direct Connection big block double roller timing chain #P4120264. $75
New Mr. Gasket chrome oil filter cover. $15
133 New radiator, heater hose and fuel hose clamp covers. Some chrome, some red anodized and some blue anodized. Various sizes. $75 for the lot.
MP big block high volume oil pump P4286590. This was new when I tried it on my motor but it was too much pressure so I switched to a stock pump. $80
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
NOS Cal Custom chrome dagger dipstick handle. $25
Mopar Performance 5 blade radiator fan and clutch. $100
1972 400 spark plug shields $10 pair
Factory warning light type oil pressure sending unit. $10
Chrome big block timing tab. $5
2 used Holley 450 cfm carbs, part number 9776, for dual quad set-ups. Carbs are in nice shape and worked fine the last time they were used. The only thing wrong with them is on one of them the small vacuum fitting that sticks out the side needs replacing as the tube broke off. $450 for the pair.
Chrome single groove alternator pulley. $15
New Mopar Performance big block 8 qt. oil pan with new pick-up. $200
1971 Charger big block throttle cable. $40
New AR Engineering big block lightweight alternator kit with 60 amp Denso alternator. I mounted this on my engine on the stand but ended up using a factory alternator. $175
Original 2 piece heat stove from 1970 440 exhaust manifold. Good condition. $125
1975 Date coded alternator. Part #3874271. $25
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
1967 4bbl intake manifold part# 2806178. Sandblasted and primed. $100
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Very nice condition. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $500
Prices do not include shipping. No Paypal
gt340 @ yahoo.com
TQ 9080s [Re: 6PAX] #3224129
03/31/24 10:07 PM
03/31/24 10:07 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Fitment shows 77 440
Clean but dusty, everything moves freely.
Looks like it "could" go right onto an engine and run/ but not knowing exactly when it last did just that, I have to at least recommend it to be kitted before being bolted on and run again.
Been on a shelf in my garage for who knows how long
Asking $70. Plus the ride. Or local pickup. Preferably paid for by postal MO.
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3224143
03/31/24 11:52 PM
03/31/24 11:52 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
Big block cast iron passenger side exhaust manifold
Right hand manifold has a casting date of 3751074. It's also missing the heat control valve as shown in the photos. This one is $40 (plus shipping)
Needs to be cleaned up, but otherwise appear to be in fair enough shape with no apparent cracks. PM me for more photos. Located in West Sacramento.
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3224223
04/01/24 12:34 PM
04/01/24 12:34 PM
East Brunswick, NJ
budman1965 Offline
budman1965  Offline
East Brunswick, NJ
Pair of big block spool mounts with special bolt. These fit the 1973-1974 B-body cars as well as the big block Direct Connection A-body K-frame. Not sure if these are new or just very clean and hardly used. Asking $30 for the pair. Contact Bud: Kramden426 at aol.com
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3224240
04/01/24 12:47 PM
04/01/24 12:47 PM
East Brunswick, NJ
budman1965 Offline
budman1965  Offline
East Brunswick, NJ
Weiand intake manifold for a 413, 426W or 440 engine. Part # 7512. Looks like someone tried to do some porting. Will need some cleanup before using. Asking $100. Contact Bud: Kramden426 at aol.com
INTAKE HOLD DOWN BRACKETS, DISTRIBUTOR HOLD DOWNS [Re: budman1965] #3224268
04/01/24 01:56 PM
04/01/24 01:56 PM
BRIDGEWATER, CT.
WINGNUT Offline
WINGNUT  Offline
BRIDGEWATER, CT.
I have several used pairs of low block and raised block brackets, $15pr. Distributor hold downs, $25 each with correct bolt. Plus shipping. No Paypal, U.S. money order only. VEIGHTPETE@GMAIL.COM
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3225130
04/04/24 10:30 PM
04/04/24 10:30 PM
Heart of Iowa
Super 70 Offline
Super 70  Offline
Heart of Iowa
For Sale: Very nice and tight, Direct Connection R/B original race, tach drive electronic distributor. Part # 3690201 This unit has the cast iron body. I have had this distributor a long time and it has always been stored in my house in a spare bedroom. This is a very clean and tight unit. The shaft doesn't wobble at all and play up and down is non-existent, the clips for the cap are very tight yet when snapping them in place or unsnapping them to take the cap off. I don't think this distributor has much use on it. This is a hard to find Direct Connection distributor for a nostalgia race build with a classic tach drive tachometer ( or a "Day 2" build) as well. Asking $225.00 which includes free shipping as long as you are in the lower 48 states. PM me here or E-mail me at; cloudone.70@gmail.com ------ Also if you need more photos just let me know. Thanks.
Comp Solid Roller camshaft [Re: moparts] #3225197
04/05/24 11:14 AM
04/05/24 11:14 AM
Houston, Texas
racerx20 Offline
Standard but OK
racerx20  Offline
Standard but OK
Houston, Texas
Brand new in the box Comp Cams solid roller, specs below. $425 plus shipping.
1972 Road Runner
1988 Shelby CSX-T
440-1 Aluminum Heads Flow 363 cfm Intake $3800 [Re: moparts] #3225369
04/06/24 09:45 AM
04/06/24 09:45 AM
DC, MD Suburbs
440PURSUIT Offline
440PURSUIT  Offline
DC, MD Suburbs
Reworked Aluminum -1 Heads. Originally Done by Nic at Compu Flow.
I had reworked by Burtonsville Performance Machine (Al Callway) after engine failure and have Not run.
At this time, Exhaust valves Replaced and some intakes, New Roller Springs, Locks and Keepers, Chambers and Guides addressed as needed and surfaced.
I just had Al recheck Spring Pressures- Set up at 1.98", 270#, .700" 630#, Coil Bind .800.
Comes with NEW Manley Bolt Package
Ran 9.28 in 3200# Demon w 499.
$3800 offer with Bolts, Can Ship
Also have TTI Low Deck 2-2 1/4 Step Headers available to Purchase and other Indy Top end Parts.
Re: For Sale - Big Block Engine - 2nd Quarter [Re: moparts] #3225617
04/07/24 01:05 PM
04/07/24 01:05 PM
Cleveland, OH
TWS Offline
TWS  Offline
Cleveland, OH
NOS big block timing chain cover.
$60, plus shipping. I'm never offended by offers. TWSchuler@aol.com
2 400 4 bbl engines with 727 Transmissions [Re: moparts] #3226361
04/10/24 07:30 PM
04/10/24 07:30 PM
St. Louis, Missouri
69F8C500 Offline
69F8C500  Offline
St. Louis, Missouri
SOLD SOLD For sale: complete 400 4 bbl engines with 727 transmissions. Both are complete carb to oil pan. They are out of mid to late 70s C bodies, both have about 70K miles. Both have run recently on an engine run stand. $800 EACH. Located in Millstadt, Illinois (just outside St. Louis). If interested please contact Ryan at 314-504-0634 thanks SOLD SOLD
Re: 2 400 4 bbl engines with 727 Transmissions [Re: 69F8C500] #3226381
04/10/24 10:48 PM
04/10/24 10:48 PM
Fort Collins, Colorado
CoDart Online content
CoDart  Online Content
Edelbrock proflo-4 for RB complete kit. Used just a short time(250 miles). Absolutely nothing wrong with it, was pulled off cause of hood clearance as we are going back to stock hood. Setup ran really good. Kit comes with everything to bolt on and fire up.
$1600+shipping
Big Block Throttle Cable Bracket [Re: moparts] #3226644
04/12/24 07:24 AM
04/12/24 07:24 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Throttle Cable Bracket. Used, $30 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Call Steve 810-629-1097
383-400 Big Block A/C Brackets [Re: Memongo] #3226646
04/12/24 07:25 AM
04/12/24 07:25 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
383-400 Big Block A/C Brackets, Used, $75 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Big Block Distributor Hold Down Bracket [Re: Memongo] #3226647
04/12/24 07:26 AM
04/12/24 07:26 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Distributor Hold Down Bracket. Used, $20 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Big Block Spark Plug Wire Brackets [Re: Memongo] #3226648
04/12/24 07:27 AM
04/12/24 07:27 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Spark Plug Wire Brackets. Used, Payment via US Postal Money Order Only!. Shipping: US Address Only!
1. $10 + Shipping
2. $20 + Shipping
3. $10 + Shipping
Wire Loom Brackets 1.jpg (638 downloads)
Wire Loom Brackets 2.jpg (636 downloads)
Wire Loom Brackets 3.jpg (636 downloads)
Big Block Timing Chain Cover [Re: Memongo] #3226649
04/12/24 07:28 AM
04/12/24 07:28 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Timing Chain Cover. Used, $35 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Big Block Water Pump With Water Pump Housing [Re: Memongo] #3226650
04/12/24 07:29 AM
04/12/24 07:29 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Big Block Water Pump With Water Pump Housing. Used, $100 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Note: Came off a 1970 383 motor
Page 1 of 3 1 2 3
