Page 1 of 3 1 2 3
For Sale - Small Block Engine - 2nd Quarter #3223973
03/31/24 12:11 PM
03/31/24 12:11 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Cast iron dual point distributor [Re: 19Coronet66] #3224127
03/31/24 09:49 PM
03/31/24 09:49 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Numbers say 58 392 hemi. Placed tip to flange with a 70s SB distributor it's the same depth as the SB distributor
Asking 100 plus the ride
Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts] #3224154
04/01/24 07:30 AM
04/01/24 07:30 AM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
70 B-body voltage regulator mounting bracket. $15
New chrome coil cover & coil mounting bracket. $20
NOS Cal Custom chrome radiator cap. $20
NOS Cal Custom chrome battery hold down. $25
Four new extra wide chrome valve cover hold down clamps. $10 for the set
New exhaust manifold heat stove to air cleaner flexible hose. $20
NOS fan clutch 3769614 for 1974 all V-8 engines. $100
Factory warning light type oil pressure sending unit. $10
Gauge type oil pressure sending unit. $20
Vintage Cal Custom 14" finned aluminum air cleaner with filter. $100
1970 Style single nipple oil breather with hose. $30
New 12" oval 4 barrel finned aluminum air cleaner with filter. It measures 12" L x 8 1/4" W x 3" H and has a 5 1/8" carb opening. $55
New Mopar Performance chrome water neck. Was bolted on an engine but then taken back off before the engine was ran. $10
AC alternator bracket from a mid 70s 360. $10
New Mr. Gasket chrome oil filter cover. $15
9 Chrome t-handle valve cover bolts. $10
Factory starter, part/casting #3755259. This came off of my Dart about 10 years ago. Worked fine then, been sitting on a shelf ever since. $40
Two 318 driver side spool motor mounts pt#3642811. One is used and one is NOS. $20 for the used. $35 for the NOS.
Edelbrock Elite small block valve covers EDL-4295 with bolts, breather & PCV valve. Very nice condition. $200
NOS Cal Custom chrome dagger dipstick handle. $25
New Mopar Performance 5 blade radiator fan and clutch. $100
Pioneer Automotive cylinder head dowel pins. 21 pieces 1/4" x 5/8". $10
Howard's solid flat tappet cam for Mopar big blocks, part number CL722322-08. See links below for specifications. I bought this cam for my engine with the intention of taking the car to the track when the car was finished being restored along with the engine being built but I have changed my mind about racing the car and decided to go with a milder hydraulic cam instead. I had this cam installed in my engine on the engine stand only (engine is still on the stand) so it has never been run and is essentially new. $375
New set of COMP Cams 973-16 - Inner Valve Springs. $45
2 used Holley 450 cfm carbs, part number 9776, for dual quad set-ups. Carbs are in nice shape and worked fine the last time they were used. The only thing wrong with them is on one of them the small vacuum fitting that sticks out the side needs replacing as the tube broke off. $450 for the pair.
Chrome single groove alternator pulley. $15
1975 Date coded alternator. Part #3874271. $25
Rev-n-nator Coil and programmable ICU. $200
Vintage Cal Custom scoop style air cleaner. Includes often missing matching wingnut. $300
New in boxes QTP 2 1/2" electric exhaust cutouts #QTEC50, stainless y-pipes #10250 and remote controller #10900. $654 total price at Summit. $550
Prices do not include shipping. No Paypal
Email: gt340 @ yahoo.com
Re: For Sale - Small Block Engine - 2nd Quarter [Re: 6PAX] #3225302
04/05/24 08:55 PM
04/05/24 08:55 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
For Sale. Indy rockers 1.6 for 360-1 heads , no longer available from Indy , I am told they fit big blocks also , these were spares I sold the motor $100 shipping extra lbvracing@aol.com of pm
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts] #3225349
04/06/24 06:09 AM
04/06/24 06:09 AM
Beaumont
1007bond Offline
1007bond  Offline
Beaumont
have these heads still in the box went big block instead want $1200 cwkerr007@gmail.com prob won't get me there so pm at four 0 nine 2 four 2 one 4 00
Re: For Sale -ATK High Performance Chrysler 408 A Stroker [Re: moparts] #3225626
04/07/24 01:20 PM
04/07/24 01:20 PM
Parsippany, New Jersey
340challconvert Offline
ATK High Performance Chrysler 408 A Stroker Short Block SP61 For Sale NEW REBUILD
Purchased this engine for a potential high performance build from Summit. Had my 340 rebuilt instead
Engine still factory packed, protected in shipping crate.
-Mopar Small Block Magnum
-Actual Engine Displacement: 6.7L/408
-Rear Main Seal Style:- 2-piece
-Crankshaft Material:-Nodular iron
-Piston Material:-Hypereutectic aluminum
-Short Block Piston Style:-Dish
-Connecting Rod Beam Style:-I-beam
-Engine Block Material:-Cast iron
-Main Journal Type- Mopar LA Large
-Deck Height (in.): 9.600 in.
-Engine Balance:- Internal
ATK High Performance Chrysler 408 A Stroker short blocks include the following:
* Handpicked and seasoned OE Magnum 1993-2001 blocks
* Aligned and hone main bores
* Nodular iron internally balanced crankshaft
* 4.00 in. stroke
* 4340 forged I beam connecting rods with ARP 8740 bolts
* Hypereutectic pistons with 23.5cc dish
* Plasma-moly rings
* Approximate Compression Ratios: 62cc = 9.7:1 / 68cc = 9.2:1 / 72cc = 8.9:1
Selling below my expenditure (original core charge and shipping was over $550 plus cost of short block)
Sell for $2800. Pick up only from 07054 Parsippany, NJ
PM with interest 201-274 4887 or email a66challengerregistry61@yahoo.com
Phil
1970 A-66 340 Challenger convertible
Re: For Sale - Small Block Engine - 2nd Quarter [Re: moparts] #3225903
04/08/24 08:35 PM
04/08/24 08:35 PM
oak park, il.
dsd70bee Offline
dsd70bee  Offline
oak park, il.
1970 340 intake manifold, nice used condition $250.00 (708) 288-2879
340 intake 001.JPG (439 downloads)
340 intake 002.JPG (438 downloads)
340 intake 005.JPG (438 downloads)
340 intake 006.JPG (436 downloads)
Custom Small Block 3,4 Speed Throttle Cable Bracket [Re: moparts] #3226609
04/12/24 03:13 AM
04/12/24 03:13 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Custom Small Block 3,4 Speed Throttle Cable Bracket. Used, $25 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Call Steve 810-629-1097
Note: Works with any high rise intake or carburetor spacer
W-2 Small Block Throttle Cable Bracket [Re: Memongo] #3226610
04/12/24 03:14 AM
04/12/24 03:14 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
W-2 Small Block Throttle Cable Bracket. New, $15 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Small Block Carburetor Throttle Return Spring Brackets [Re: Memongo] #3226611
04/12/24 03:27 AM
04/12/24 03:27 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Small Block Carburetor Throttle Return Spring Brackets. Used, $15 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Factory Small Block Valve Covers 318,340,360 [Re: Memongo] #3226612
04/12/24 03:28 AM
04/12/24 03:28 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Factory Small Block Valve Covers 318,340,360, Used, $50 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Note: All Harness, Wire Brackets Intact!
Factory Small Block Valve Cover Breather [Re: Memongo] #3226613
04/12/24 03:29 AM
04/12/24 03:29 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Factory Small Block Valve Cover Breather. Used, $15 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Valve Cover Oil Fill Caps [Re: Memongo] #3226614
04/12/24 03:30 AM
04/12/24 03:30 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Valve Cover Oil Fill Caps. Used, $10 Each + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
1. Not sure!
2. 73-74 model (came of my 73 Cuda)
3. Mopar Preformance Chrome New!
Note: Pick the one you want by photo 1-3
Oil Cap 2.jpg (322 downloads)
Oil Cap 3.jpg (324 downloads)
Oil Cap Chrome.jpg (321 downloads)
Small Block Spark Plug Wire Looms [Re: Memongo] #3226615
04/12/24 03:31 AM
04/12/24 03:31 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Small Block Spark Plug Wire Looms. Used, All 7 Looms, $25 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Small Block Heater Hose Bracket [Re: Memongo] #3226616
04/12/24 03:32 AM
04/12/24 03:32 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Small Block Heater Hose Bracket. Used, $15 + Shipping. Payment via US Postal Money Order. Shipping: US Address Only!
Small Block Distributor Hold Down Bracket [Re: Memongo] #3226617
04/12/24 03:34 AM
04/12/24 03:34 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Small Block Distributor Hold Down Bracket. Used, $15 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
P4120484 Fuel Pump Eccentric Small Block 273, 318, 340, 360 [Re: Memongo] #3226618
04/12/24 03:35 AM
04/12/24 03:35 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
P4120484 Fuel Pump Eccentric Small Block 273, 318, 340, 360. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Photo 1. Used, $20 + Shipping
Casler Small Block Headers 273, 318, 340, 360 [Re: Memongo] #3226619
04/12/24 03:38 AM
04/12/24 03:38 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Casler Small Block Headers 273, 318, 340, 360. Used, $150 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Small block headers.jpg (317 downloads)
Water Pump To Fan Spacer 1.25 in' Thick [Re: Memongo] #3226620
04/12/24 03:42 AM
04/12/24 03:42 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Water Pump To Fan Spacer 1.25 in' Thick. Used $15 + Shipping. Payment via US Postal Money Order Only!. Shipping: US Address Only!
Fan Spacer 1.25 in.jpg (313 downloads)
Temperature Sending Unit / Oil Pressure Sending Unit [Re: Memongo] #3226621
04/12/24 03:43 AM
04/12/24 03:43 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
63-76 Temperature Sending Switch #2426458 Used $7.50 + Shipping
62-80 Oil Pressure Sending Unit For Models With Warning Light. Used, $7.50 + Shipping.
Page 1 of 3 1 2 3
