Gas Leak #3226032
04/09/24 01:03 PM
04/09/24 01:03 PM
Sunshine State
Crosshairs Offline OP
Sunshine State
1989 Dakota 3.9 2wd. I have a small gas leak on top of my gas tank. I assume it's not the feed line because I don't have any drivability issues, hesitation or stumbling like its starving for fuel. Return line??
Re: Gas Leak [Re: Crosshairs] #3226042
04/09/24 01:21 PM
04/09/24 01:21 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Sounds like it's time to lift the bed and find out for sure. twocents
Re: Gas Leak [Re: Fat_Mike] #3226043
04/09/24 01:26 PM
04/09/24 01:26 PM
Sunshine State
Sunshine State
Yea, have to round up some extra hands!
Re: Gas Leak [Re: Crosshairs] #3226053
04/09/24 02:45 PM
04/09/24 02:45 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
Likely a hole in the one of the fuel lines. On top of the tank, wouldn't be a hole in the tank as it would only leak when near full.
My Monster are real!
Living within your means makes life pretty easy.
Re: Gas Leak [Re: 67vertman] #3226169
04/09/24 10:52 PM
04/09/24 10:52 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I would expect a hole in one or both of the steel fuel lines. I would also replace both fuel lines from the tank to the braded steel hoses at the same time. That black plastic line (Pec?) works pretty well. Depending on the year, some of those lines are under a lot of pressure, hoses and clamps don't work very well.
Re: Gas Leak [Re: Crosshairs] #3226283
04/10/24 02:03 PM
04/10/24 02:03 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
