1965 Trunion front joint #3225847
04/08/24 04:10 PM
04/08/24 04:10 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Checking experience using this joint instead of a slip joint, mild racing with 413, 9” tire, 3800 vert, 3400 pounds.
I know I could use later trans but would like to keep the cable.
Re: 1965 Trunion front joint [Re: cudaman1969] #3225928
04/08/24 10:47 PM
04/08/24 10:47 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
65 had cables and slip joint .
never broke my trunion joint 12.8 with my 413 3880 lb
Re: 1965 Trunion front joint [Re: cudaman1969] #3225930
04/08/24 10:49 PM
04/08/24 10:49 PM
1965 727 pushbutton should have the later better style U joint, not on the 4 speed cars in 1965 though. They kept the ball and trunnion shafts with NP833 early style output shaft and 4 bolt tranny style front U joints shruggy
Re: 1965 Trunion front joint [Re: Cab_Burge] #3225984
04/09/24 08:48 AM
04/09/24 08:48 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
If your ball and trunion shaft is in good shape you won't have an issue. Now a days there are many OEM shaft that bolt on in the same manner. So upgrades are available. Swapping from the 62-64 tailhousing and output shaft to 65 parts will allow you to run a standard style drive shaft. Though there is a raised area just ahead of the output splines on a 65 shaft. The later yoke needs to be shortened about 5/16".
Doug
Re: 1965 Trunion front joint [Re: dvw] #3226026
04/09/24 12:48 PM
04/09/24 12:48 PM
moparx Offline
moparx  Offline
Doug
when you say the later yoke needs shortened, is that the factory style with the [approximately 1" of missing splines at the front], or the shorter aftermarket style with the yoke having all splines, or both ?
beer
Re: 1965 Trunion front joint [Re: moparx] #3226035
04/09/24 01:07 PM
04/09/24 01:07 PM
fredericksburg,va
fredericksburg,va
64 trans in a 65. I’m using my 65 trans in my 64
Re: 1965 Trunion front joint [Re: cudaman1969] #3226073
04/09/24 04:16 PM
04/09/24 04:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Can't sat which yokes. I just test fit them. A 10" cut off wheel in a miter saw is slow but cuts them with no issue. you can see the rib im talking about.
Doug.
Re: 1965 Trunion front joint [Re: cudaman1969] #3226078
04/09/24 04:30 PM
04/09/24 04:30 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 65 440 with 600 HP 4 speed and its the original never been apart.Ive broke rears but the front just keeps going My 57 Chrysler had the same just replaced a bad boot on it Never a problem
Chrysler Firepower
Re: 1965 Trunion front joint [Re: dvw] #3226128
04/09/24 07:57 PM
04/09/24 07:57 PM
fredericksburg,va
fredericksburg,va
Doug.
That rib is to keep the o-ring (a ribbed affair about an inch long) in the slip joint so trans fluid won’t run back out the splines. All the slip joints I have are smooth in the front half, no splines. If that trunion will hold up to a 600 inch Hemi I’ll use that trans in the 64.
