line lock and proportioning valve location #3225400
04/06/24 11:47 AM
04/06/24 11:47 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
The attached photo is a pretty tidy install but I can't tell where the specific lines run. If this is your car, can you please post another photo or two of the line routing into the linelock and prop valve.
Anyone else with tidy installs is also welcome to post. I'm trying to not mount anything on the sheet metal (firewall or inner fenders) or frame rails.
Re: line lock and proportioning valve location [Re: Stanton] #3225422
04/06/24 01:34 PM
04/06/24 01:34 PM
Boise
Moparteacher Offline
Boise
I'm not interely clear as to what you're asking, but proprtioning valve goes to the rear tires. It limits maximum pressure to help prevent lock-up in a panic or hard brake.
Line lock traditionally goes to the front tires.
Re: line lock and proportioning valve location [Re: Moparteacher] #3225431
04/06/24 02:23 PM
04/06/24 02:23 PM
iagree up OP work up wrench up
Usually the rear port is for the disc brakes, the front for the rears. Their should be no 10lb. residual pressure check valve in the disc brake port scope wrench
Re: line lock and proportioning valve location [Re: Cab_Burge] #3225567
04/07/24 11:19 AM
04/07/24 11:19 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
I thought I was pretty clear ... that I want to see how he ran his lines. I'm well aware of what goes where.
Re: line lock and proportioning valve location [Re: Stanton] #3225596
04/07/24 12:34 PM
04/07/24 12:34 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Pretty sure thats Sean, HardcoreB's car...
Re: line lock and proportioning valve location [Re: Al_Alguire] #3225775
04/08/24 12:22 PM
04/08/24 12:22 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
I mounted mine on the other side of the proportioning valve (used the existing mount).
Re: line lock and proportioning valve location [Re: 76Beeper] #3225844
04/08/24 03:53 PM
04/08/24 03:53 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Re: line lock and proportioning valve location [Re: Stanton] #3225932
04/08/24 10:51 PM
04/08/24 10:51 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Here's where I mounted the proportioning valve:
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: line lock and proportioning valve location [Re: Stanton] #3225948
04/09/24 01:38 AM
04/09/24 01:38 AM
Why? work shruggy
Re: line lock and proportioning valve location [Re: Cab_Burge] #3225983
04/09/24 08:26 AM
04/09/24 08:26 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Because I can !!
Re: line lock and proportioning valve location [Re: Stanton] #3226036
04/09/24 01:09 PM
04/09/24 01:09 PM
Because I can !!
up Only in America grin work stirthepot whistling
Re: line lock and proportioning valve location [Re: Cab_Burge] #3226040
04/09/24 01:17 PM
04/09/24 01:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I totally get NOT drilling holes to mount stuff - I'm generally loath to do that myself.
Race cars are a different matter, but even then I try to avoid it.
I have drilled holes in race cars when serviceability dictate them and the car will never be restored to stock, but not on my street/restored/minty stuff.
That photo shows an elegant & compact installation.
Re: line lock and proportioning valve location [Re: topside] #3226153
04/09/24 09:00 PM
04/09/24 09:00 PM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
Well, I don’t live in America. And I hate drilling holes in a panel today only to have technology change and have to drill new holes next week! Not that a line loc or prop valve is likely to change any time soon but you get my drift. And I just spent WAY too much on paint and bodywork to start drilling holes in it !!
Re: line lock and proportioning valve location [Re: Stanton] #3226186
04/10/24 06:19 AM
04/10/24 06:19 AM
No insult meant about living here in America blush
Planning and prefabbing help prevent unwanted holes and changes later after you get upset about where a race part is mounted, I mounted my aftermarket purporting valve in the brake line going to the rear end under the floorboards around the tranny crossmember
Re: line lock and proportioning valve location [Re: Stanton] #3226188
04/10/24 06:44 AM
04/10/24 06:44 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Sorry I haven't logged-in to notice this post. I used an offset master mount plate I believe from AndyF? Then I made this plate to mount the prop valve and line-loc. I'll get more pics if they help but currently this is all I have...https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/download/Number/358717/filename/20170122_000346.jpg
Re: line lock and proportioning valve location [Re: HardcoreB] #3226201
04/10/24 07:00 AM
04/10/24 07:00 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Tried to link the pic which is on the first page of the thread I made called 'Build Share' in the members projects section. That MC has transverse thru holes which I used for long g8 1/4x28 bolts which mount the plate I made after laying out the packaging to accommodate the tightest bends using hard line. I already had my headers made and engine permanently mounted so I routed the lines respectively. I used the factory frame tabs for the front lines and then ran -3 braided Earls to the calipers.
Re: line lock and proportioning valve location [Re: Stanton] #3226204
04/10/24 07:02 AM
04/10/24 07:02 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
I did this for all those reasons AND if there's a leak at a connection...it'll be away from the paint.
Re: line lock and proportioning valve location [Re: HardcoreB] #3226217
04/10/24 09:27 AM
04/10/24 09:27 AM
Ontario, Canada
Stanton Offline OP
Don't question me!
Stanton  Offline OP
Don't question me!
Ontario, Canada
In the photo on the link it looks like the prop valve is plumbed into the line loc. so are you using the prop valve on the front brakes or the line loc on the rear ??
Re: line lock and proportioning valve location [Re: Stanton] #3226226
04/10/24 10:12 AM
04/10/24 10:12 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Rear port MC to prop valve IN. Prop OUT to line-loc IN. Line-loc OUTLETS to front brakes.
Re: line lock and proportioning valve location [Re: HardcoreB] #3226284
04/10/24 02:18 PM
04/10/24 02:18 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
My p valve is just right of the M/C
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
