Tire size with DrDiff 1" offset spring mounts
#3225407
04/06/24 12:16 PM
04/06/24 12:16 PM
Posts: 4,722 Moved to N.E. Tennessee
GomangoCuda
Ebody Barracuda. 275/60 dot drag radials fit easy without the offset stuff. Least clearance is the sidewalk to spring behind the axle. What tires have you been able to fit with the offset springs? Does this kit move both the front and back of the spring 1" or is the shackel offset more than the front bracket to bring the springs closer to being parallel?
For reference
Re: Tire size with DrDiff 1" offset spring mounts
[Re: DaveRS23]
#3225470
04/06/24 06:31 PM
04/06/24 06:31 PM
Posts: 4,727 Florida
BDW
Dr Diff 1" relo on E-body rear end, 9" rims with 6" backspace, 275/40/18
[Re: GomangoCuda]
#3225767
04/08/24 12:12 PM
04/08/24 12:12 PM
Posts: 3,278 West Coast, USA
jbc426
West Coast, USA
I squeezed in a set of 325/50-15 Nitto's. on 10 inch rims with 4 1/2" backspacing and a 1/4" thick steel spacer. It has a '68 B-Body Dana 60 with Dr Diff's inset hanger kit. I did have to massage the upper fender-well lip slightly.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
