Re: Mini starter question
[Re: mickm]
#3225398
04/06/24 11:43 AM
04/06/24 11:43 AM
Posts: 1,285 okla.
sam64
okla.
It's the contacts that the plunger connects to complete the circuit. yes it is repairable.You can get the plunger/contact kit on Amazon for 14.00
[Re: moparx]
#3225501
04/06/24 10:01 PM
04/06/24 10:01 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
It's the contacts that the plunger connects to complete the circuit. yes it is repairable.You can get the plunger/contact kit on Amazon for 14.00 plus, it's a super easy thing to do ! also, you may just find a little polishing of the contacts is all it needs. i have run into that several times over the years. ^^^ this ... Mick you can order the plunger but in the mean time pull it and open up the solenoid , you'll probably see it's pitted , clean it up and that may be all it needs?
[Re: Cab_Burge]
#3225523
04/06/24 11:46 PM
04/06/24 11:46 PM
Posts: 15,348 Omaha Ne
TJP
Omaha Ne
Agreed Especially so at the battery. God forbid you have the repair a cable connectors at the battery as they are notorious for your exact issue
[Re: JohnRR]
#3225547
04/07/24 09:53 AM
04/07/24 09:53 AM
Posts: 6,240 nowhere
Sniper
nowhere
It's the contacts that the plunger connects to complete the circuit. yes it is repairable.You can get the plunger/contact kit on Amazon for 14.00 plus, it's a super easy thing to do ! also, you may just find a little polishing of the contacts is all it needs. i have run into that several times over the years. ^^^ this ... Mick you can order the plunger but in the mean time pull it and open up the solenoid , you'll probably see it's pitted , clean it up and that may be all it needs? Had a similar issue on the direct drive starter my 64 300 had. Ended up flipping the copper disc around and all was good.
