Indexing QT Bellhousing
#3224644
04/03/24 07:36 AM
04/03/24 07:36 AM
Posts: 1,320 Lees Summit, MO
BrianT
Lees Summit, MO
I'm installing a used QT bellhousing on my 70 Duster with a 318. Transmission is an 18 spline A body four speed. The engine is in the car.
The instructions I found online recommend indexing the bellhousing to correct any misalignment between the engine and transmission. I understand that this is critical when using a TKX or TKO due to the tapered input shaft bearing. Is this process necessary when using a NP transmission with it's roller bearings?
I'm working by myself and it is impossible to rotate the front of the engine and watch the bell from the back. Thanks for any help or guidance!
1970 Duster 340 clone
Re: Indexing QT Bellhousing
[Re: BrianT]
#3224685
04/03/24 10:11 AM
04/03/24 10:11 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Yes you have to do it and buy these BEFORE you start . RobbMc dowels .Buy these from Robb Mc , summit sells lakewood branded ones like these and just a pair of those cost a little more than buying all 3 offsets from Robb. The old lakewoods that are marked Mopar/Ford and NOT Mopar , they are .500 which is Ford , Mopars are .496.
[Re: JohnRR]
#3224895
04/03/24 10:45 PM
04/03/24 10:45 PM
Posts: 15,350 Omaha Ne
TJP
Omaha Ne
Yes you have to do it and buy these BEFORE you start . RobbMc dowels .Buy these from Robb Mc , summit sells lakewood branded ones like these and just a pair of those cost a little more than buying all 3 offsets from Robb. The old lakewoods that are marked Mopar/Ford and NOT Mopar , they are .500 which is Ford , Mopars are .496. I agree with ALL said. if you remove the plugs you might be able to rotate the motor using the pressure plate bolts following the ARC of the FW with a box end wrench. One can also install the starter and use a remote switch
[Re: TJP]
#3224931
04/04/24 07:24 AM
04/04/24 07:24 AM
BrianT
Lees Summit, MO
Thanks for the replies and advice everyone. I guess I was looking for someone to tell me that it wasn't necessary when I knew in my heart that it was?
So far, the plugs are out, the block plate is on as is the flywheel. I will bolt the bellhousing on and get the dial indicator set up. I have a buddy who says he can come by this weekend to help spin the engine while I write down the readings. It seems pretty straight forward from there. I have watched numerous YouTube videos on the subject.
Thanks for the heads up about the size of the dowels. I was looking on Summit's page and they list Ford/Mopar as .500", but if you look at the reviews there are comments from the Mopar guys saying that are too tight and needed to be modified. This saved me a HUGE amount of frustration in the near future. I will order the correct dowels from the link provided above.
Hopefully, I'll update this thread later in the week with good news. Thanks again!
[Re: Droop69]
#3225040
04/04/24 02:46 PM
04/04/24 02:46 PM
Posts: 8,871 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Why do you have an 18 spline trans behind a 318? Hell, why not ?!?! It's not like they're any heavier or anything !
[Re: Droop69]
#3225045
04/04/24 03:19 PM
04/04/24 03:19 PM
BrianT
Lees Summit, MO
Why do you have an 18 spline trans behind a 318? Just curious seems like way overkill appplication. I'm having Brian Hafliger at IMM build me a 340 based W2 stroker motor. It should be ready later this summer.
[Re: BrianT]
#3225052
04/04/24 03:50 PM
04/04/24 03:50 PM
Posts: 18,415 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Hopefully, I'll update this thread later in the week with good news. Thanks again! Read above JohnRR told you where to get the dowels And they fit.
[Re: NITROUSN]
#3225077
04/04/24 05:41 PM
04/04/24 05:41 PM
BrianT
Lees Summit, MO
I did. That's why I thanked him for the info?
[Re: BrianT]
#3225163
04/05/24 07:56 AM
04/05/24 07:56 AM
Posts: 958 MN
Droop69
MN
Why do you have an 18 spline trans behind a 318? Just curious seems like way overkill appplication. I'm having Brian Hafliger at IMM build me a 340 based W2 stroker motor. It should be ready later this summer. That makes sense!
[Re: BrianT]
#3225168
04/05/24 09:07 AM
04/05/24 09:07 AM
JohnRR
U.S.S.A.
I did. That's why I thanked him for the info? Glad I could help. I think he might have missed that statement , I know sometimes I miss things ... getting old ...
[Re: JohnRR]
#3225267
04/05/24 05:27 PM
04/05/24 05:27 PM
BrianT
Lees Summit, MO
Glad I could help.
Aren't we all. I hope I can get this thing on the road soon and start making more memories.
[Re: BrianT]
#3225312
04/05/24 11:06 PM
04/05/24 11:06 PM
TJP
Omaha Ne
Glad I could help.
Aren't we all. I hope I can get this thing on the road soon and start making more memories. the question of the day is: Will you remember the memories 😂, Or will they be Memorex? ❓❓ This is an Alzheimer's test question 🙄
[Re: TJP]
#3226892
04/13/24 02:47 PM
04/13/24 02:47 PM
BrianT
Lees Summit, MO
Success! My buddy came by today and we spent the morning measuring and remeasuring. We found .032 total run out so we divided by two and got .016. I just ordered the .014 offset dowels from RobbMC at the link above. Thanks everyone for their help and input!
[Re: BrianT]
#3226950
04/13/24 10:28 PM
04/13/24 10:28 PM
TJP
Omaha Ne
[Re: BrianT]
#3227029
04/14/24 01:20 PM
04/14/24 01:20 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Did you also verify that the bellhousing's transmission mounting face is square to the back of the block? Mine are usually off a bit from square, and I use hardend prescision washers to adjust that.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
