thoughts on 727 transmission pan studs ?
#3224998
04/04/24 12:27 PM
04/04/24 12:27 PM
Posts: 19,406 north of coder
moparx
was thinking on swapping out the usual bolts for studs while swapping the MP chrome pan for a cast aluminum pan. however, the "stud kits" i have seen are just long 5/16x18 set screws. i would much rather prefer the 5/16x18 to 5/16x24 style studs, then use 5/16x24 serrated flange nuts to secure the cast pan. thoughts/opinions, pros/cons on this ? TIA !
Re: thoughts on 727 transmission pan studs ?
[Re: moparx]
#3225004
04/04/24 12:37 PM
04/04/24 12:37 PM
Posts: 16,925 NC
440Jim
NC
I have only ever used bolts. But those castings can easily be stripped, so studs sound like a nice touch to me. Everything you said about the serrated nuts sounds good also, since the gasket should NOT be over torqued. Might be a little overkill, but I can't knock it. If you want to spend the money on ARP studs, be my guest. But simple coarse threads with common serrated flanged nuts should be just fine, IMO. Check around the shifter area. If the cable bracket mounts to the pan, there might be a reason to use bolts for maintenance/space reasons. And if the pan has an internal baffle around the filter, the pan might not drop down far enough to clear the studs without moving rearward. Measure twice...
[Re: moparx]
#3225008
04/04/24 12:44 PM
04/04/24 12:44 PM
Posts: 43,185 Bend,OR USA
Cab_Burge
I'm using 5/16 set screws along with the serrated nuts on my all aluminum KB wedge motor oil pan fasteners on the aluminum Charlies oil pan I hope they hold up okay
[Re: Cab_Burge]
#3225074
04/04/24 05:38 PM
04/04/24 05:38 PM
Posts: 5,821 ohio
ruderunner
ohio
I don't think studs should pose any problems. Check AuVeCo and see what they offer.
Angry white pureblood male
[Re: moparx]
#3225164
04/05/24 08:01 AM
04/05/24 08:01 AM
Posts: 2,112 Byron, NY
W.I.N. Racing
Byron, NY
was thinking on swapping out the usual bolts for studs while swapping the MP chrome pan for a cast aluminum pan. however, the "stud kits" i have seen are just long 5/16x18 set screws. i would much rather prefer the 5/16x18 to 5/16x24 style studs, then use 5/16x24 serrated flange nuts to secure the cast pan. thoughts/opinions, pros/cons on this ? TIA ! This would be my preference also...if I were to stud a Transmission pan
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3225192
04/05/24 10:48 AM
04/05/24 10:48 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I have my pan studed with ARP studs. 50+ year old cases. It does help from stripping any case threads.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Cab_Burge]
#3225318
04/05/24 11:26 PM
04/05/24 11:26 PM
Posts: 11,570 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Since we are talking about transmission pans and using studs in the case, or not...
studs would be okay, but I typically Heli-coil all the holes, before they get striped. And use a torque wrench to tighten the bolts. You're not going to damage the case using the proper tools and torque specs.
