Oil pressure gauge line leaked --> need new carpet
#3224949
04/04/24 09:40 AM
04/04/24 09:40 AM
Posts: 1,125 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Not sure why, cuz the connections are very straight forward, but the AutoMeter mechanical oil pressure gauge in the '73 leaked at the fitting during the initial start-up and soaked the d-a-mn carpet w/ 10w40. Nothing looked wrong, but...
Anyone trust electric oil pressure gauges instead of mechanical? I always wanted mechanical for "real time" response & readings, but am now wondering if I should swap it out.
$.02 either way appreciated. Thx
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Oil pressure gauge line leaked --> need new carpet
[Re: Brad_Haak]
#3224953
04/04/24 09:51 AM
04/04/24 09:51 AM
Posts: 9,454 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
initial start-up- Was the gauge new, was it a new install? If not how old was the line? Plastic/copper line? Id not let one bad time make me stray from a mech. gauge as much as it stinks it happened. Ive had a few of the plastic line units develop a drip after many years so I just bought the line/fitting kit and all was good. Not sure why, cuz the connections are very straight forward, but the AutoMeter mechanical oil pressure gauge in the '73 leaked at the fitting during the initial start-up and soaked the d-a-mn carpet w/ 10w40. Nothing looked wrong, but...
STOP POTATO HATE!
[Re: rickraw]
#3224956
04/04/24 09:53 AM
04/04/24 09:53 AM
Brad_Haak
Loudoun County, VA
New AutoMeter gauge with new AutoMeter braided line kit
[Re: Brad_Haak]
#3224972
04/04/24 10:57 AM
04/04/24 10:57 AM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Dawn Platinum and hot water washes it right out.
DAMHIK
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#3224979
04/04/24 11:24 AM
04/04/24 11:24 AM
Brad_Haak
Loudoun County, VA
There's a brand new ACC carpet sitting in my basement waiting for me to pull the interior out... but I haven't been motivated to mess with it
[Re: Brad_Haak]
#3224988
04/04/24 12:07 PM
04/04/24 12:07 PM
Posts: 16,925 NC
440Jim
NC
New AutoMeter gauge with new AutoMeter braided line kit The braided line and AN fittings should be the best. But something didn't go right... Hard to say if it wasn't tight, debris in the AN flare, or fitting didn't seal to the hose. I would just cut off an inch and remake that end.
[Re: Cab_Burge]
#3225001
04/04/24 12:30 PM
04/04/24 12:30 PM
Posts: 19,388 north of coder
moparx
yes, 1/16 inside diameter, 1/8" outside diameter Cab. i was referring to the OD. sorry for the confusion. i also like the larger OD tubing/hose for fast response time.
[Re: moparx]
#3225005
04/04/24 12:41 PM
04/04/24 12:41 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Maybe bad fitting on the gauge end. Should be a clean -3 or -4 an male fitting there. Could be is buggered up a tad on the angle on the flare?
[Re: Brad_Haak]
#3225028
04/04/24 02:09 PM
04/04/24 02:09 PM
Posts: 2,916 A shed in England
Tig
A shed in England
Yep, same happened to me, the plastic line kinked and split a little allowing oil to drip onto the carpet, I went to an electric autometer, then to a Dakota dash. No issues, both are very responsive. IIRC the race scrutineers don't like oil lines in the drivers compartment anyway.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3225039
04/04/24 02:28 PM
04/04/24 02:28 PM
Brad_Haak
Loudoun County, VA
Just checked out AutoMeter's electrical options: a standard version about the same $ as the mechanical I have now, and a "hi zoot" version that's supposed to be very sensitive to pressure changes.... but also costs 3-4 times what the simpler gauges do
Will give the current fittings and hose a good close look and see if anything obvious is jacked up, then go from there
[Re: Brad_Haak]
#3225041
04/04/24 02:51 PM
04/04/24 02:51 PM
Posts: 8,870 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
That supplied line is probably from chino Well sheeet, there's your problem !!!
