Wilwood Polymatrix pads conundrum #3224888
04/03/24 09:53 PM
04/03/24 09:53 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I had read where these pads worked better and improved stopping distances so I bought a set. I had also read where they don't put off any more brake dust than the original pads. Well, they stop much better, but the dust is crazy! After a short 30 mile round trip to work and taking it to lunch, my front wheels look like garbage! Maybe I'm just picky, but is there another compound or manufacturer that makes a pad that doesn't put off so much dust yet stops well?!
'63 Dodge 330
11.19 @ 121 mph
Re: Wilwood Polymatrix pads conundrum [Re: GY3] #3224910
04/04/24 12:24 AM
04/04/24 12:24 AM
AndyF Offline
AndyF  Offline
Depending on the caliper design Wilwood has about a dozen pad compounds. Softer ones stop quicker but wear faster, harder is the opposite. You might be able to just step up a notch or two from the one you have and find a happy medium.
Re: Wilwood Polymatrix pads conundrum [Re: AndyF] #3224943
04/04/24 08:59 AM
04/04/24 08:59 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
It's the Dynalite caliper.
'63 Dodge 330
11.19 @ 121 mph
Re: Wilwood Polymatrix pads conundrum [Re: GY3] #3224947
04/04/24 09:33 AM
04/04/24 09:33 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I run whatever compound came with my drag brake setup. They stop very well, they are dusty but not terrible. Adding the rear discs cut down on the dust from the front more than I realized at first.
I always thought Mokan was hard on the brakes until I committed to the first turnoff at Carolina Dragway last year on drag week. It was a confidence booster for my brake system and probably about a %20 hit in pad life lol.
68 Barracuda Formula S 340
Re: Wilwood Polymatrix pads conundrum [Re: Bad340fish] #3224954
04/04/24 09:52 AM
04/04/24 09:52 AM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
I just switched from BP-10 to BP-20 pads. They were double the price but suppose to stop better and less dust. The BP-10's throw off a lot of dust.
Re: Wilwood Polymatrix pads conundrum [Re: GY3] #3224977
04/04/24 11:18 AM
04/04/24 11:18 AM
AndyF Offline
AndyF  Offline
Check the box to see which compound you have and then see what else is available for that caliper. Dynalites are popular so there are probably a lot of choices.
https://www.wilwood.com/BrakePads/BrakePadsApp
Re: Wilwood Polymatrix pads conundrum [Re: GY3] #3224982
04/04/24 11:30 AM
04/04/24 11:30 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
I run the BP-20's - big difference from what came it the kit BP-10's - I run the BP20's on all four corners
