904 bell housing bolts
#3224375
04/01/24 08:30 PM
04/01/24 08:30 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
Wanting to replace the bolts for bolting the transmission onto the engine, what is in it now are whatever someone had on hand. Anyone know what size(s) and hardness I need and did they use lock washers?
11B40
Re: 904 bell housing bolts
[Re: TJP]
#3224398
04/01/24 10:45 PM
04/01/24 10:45 PM
Posts: 43,185 Bend,OR USA
Cab_Burge
hi
grade 5 with conical washers
I seem to recall captive lock washers on the bolts Correct originally, don't forget about the two 7/16 bolts on the lower block going into the trans.case, one under the starter and the other on the passenger side down low also bolting into the tranny case
