Re: Most basic engine swap question ever
[Re: IMGTX]
#3224214
04/01/24 12:22 PM
04/01/24 12:22 PM
Posts: 6,254 nowhere
Sniper
nowhere
360's require a different oil pan, an externally balanced flexplate, and motor mount bracket on one side.
Lots of good help here if you run into a snag.
OR an eternally balanced toque converter, which is how the factory did it. Be advised, Magnum 5.9's are also eternally balanced, but the amount is different than the LA 360. As for the motor mount bracket, the 318 bracket is 1/2" wider than the 360 one, a spacer (1/2" nut) fixes that.
[Re: Sniper]
#3224318
04/01/24 03:59 PM
04/01/24 03:59 PM
Posts: 10,563 Freeport IL USA
poorboy
Freeport IL USA
OR an eternally balanced toque converter, which is how the factory did it. Be advised, Magnum 5.9's are also eternally balanced, but the amount is different than the LA 360. As for the motor mount bracket, the 318 bracket is 1/2" wider than the 360 one, a spacer (1/2" nut) fixes that. You missed the part where he said he had a 4 speed. He also stated he has a 7 1/4 rear end as well. He would need a 360 balanced flywheel of the same diameter he currently has. Between the oil pan, the flywheel, and the 7 1/4, he has several reasons to be sure the "new" motor is a 318 and not a 360, and he has a pretty good reason to be sure it is not the Magnum 5.2 or 5.9 motor either.
[Re: volaredon]
#3224349
04/01/24 05:52 PM
04/01/24 05:52 PM
Posts: 4,417 Michigan
MarkZ
Worthy
Worthy
Pull a 318 out of F/J/M car. They're still around in yards. '85+ had factory roller cams. Not power houses, but will make for a very nice cruising motor with off-idle torque all through to 4500.
