Oil filter on 5.7l with high pressure pump #3223759
03/30/24 05:03 PM
03/30/24 05:03 PM
St Louis
Skippingears Offline OP
St Louis
I just recently did a cam swap on my 5.7l due to lifter failure and installed the mellings high pressure oil pump as well, I was wondering if I should run a oil filter without the bypass. I run wix usually which I understand has a 22 psi pressure differential bypass
Re: Oil filter on 5.7l with high pressure pump [Re: Skippingears] #3223901
03/31/24 09:01 AM
03/31/24 09:01 AM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
use same filter.
