Re: Trick Flow Track Heat 440 int vs Edelbrock Victor 440 int? [Re: AndyF] #2378299
09/28/17 02:36 PM
09/28/17 02:36 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
If you look closely at the pics above of both the stock Trick Flow and Victor 440 intakes, you'll see that is how both brands cast the floors of their intakes. Not really a turtle IMO, but maybe something to reduce fuel pudding. I think of turtles as being used more for tuning fuel distribution.
Re: Trick Flow Track Heat 440 int vs Edelbrock Victor 440 int? [Re: PorkyPig] #2378327
09/28/17 03:32 PM
09/28/17 03:32 PM
an8sec70cuda Offline
Thanks Andy and Brad. After looking at the "before" pics again, I see what you're talking about Brad. Didn't notice it before.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Trick Flow Track Heat 440 int vs Edelbrock Victor 440 int? [Re: PorkyPig] #2378913
09/29/17 03:53 PM
09/29/17 03:53 PM
long time lurker, short time p...
P
PorkyPig Offline OP
PorkyPig  Offline OP
P
Ok, it's 9 months after I started this. Has anyone seen a test that uses both intakes on the same engine?
Re: Trick Flow Track Heat 440 int vs Edelbrock Victor 440 int? [Re: PorkyPig] #3059835
07/17/22 04:32 AM
07/17/22 04:32 AM
West Central Indiana
PROSTOCKTOM Offline
PROSTOCKTOM  Offline
5-years later there should be some answers now to all the questions asked in this thread.
Tom
Molnar Technologies Full Service Dealer - Crankshafts & Connecting Rods
Re: Trick Flow Track Heat 440 int vs Edelbrock Victor 440 int? [Re: PROSTOCKTOM] #3060022
07/17/22 08:12 PM
07/17/22 08:12 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Tom
So, 5 years later, the answers are:
1. PorkyPig is an a-hole
2. BradH is an idiot
3. Trick Flow is better out of the box
4. Both intakes are comparable if fully ported
Tony Bischoff did an Engine Masters Mopar entry some years ago where I saw pics of the engine using both intakes at different times. I believe he went with the Edelbrock because Trick Flow wasn't paying sponsorship bonus for their intake, but Edelbrock was.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Trick Flow Track Heat 440 int vs Edelbrock Victor 440 int? [Re: PorkyPig] #3223888
03/31/24 04:37 AM
03/31/24 04:37 AM
PROSTOCKTOM Offline
PROSTOCKTOM  Offline
Well I would have thought more would have commented on this thread. For what it's worth I redid the plenum on my Victor and added a homemade pyramid on the bottom.
Tom
Intake Plenum
Re: Trick Flow Track Heat 440 int vs Edelbrock Victor 440 int? [Re: PROSTOCKTOM] #3224220
04/01/24 12:29 PM
04/01/24 12:29 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
scope
