Re: Full Groove vs. 3/4 Groove Mains for BB Mopar [Re: rickseeman] #3223667
03/30/24 10:02 AM
03/30/24 10:02 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I don't think we are supposed to think about eccentricity. I don't believe we know anything about that nor is it something we can change. I think our job is to make sure the hole is the right size (2.9425"-2.943") and that we have the proper bearing
to crankshaft clearance in the vertical dimension.
2011 Drag Pak Challenger
Re: Full Groove vs. 3/4 Groove Mains for BB Mopar [Re: turbobitt] #3223698
03/30/24 12:30 PM
03/30/24 12:30 PM
Cab_Burge Online work
Cab_Burge  Online Work
It use to be the standard on the rod bearing being wider, more oil clearance at the rod joint to allow a build up of oil to, (puddle) help lubricate the bearings better as the rod rotated on the cranks wrench scope
I'm thinking between .0003 to .0005 additional clearance scope
Re: Full Groove vs. 3/4 Groove Mains for BB Mopar [Re: Cab_Burge] #3223713
03/30/24 01:50 PM
03/30/24 01:50 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
On the 119M mains I'm seeing about .002" eccentricity and consistent from hole to hole and the housing bores are perfect so I know its in the bearings.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Full Groove vs. 3/4 Groove Mains for BB Mopar [Re: turbobitt] #3223736
03/30/24 03:24 PM
03/30/24 03:24 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Is that a bad thing? What is your vertical clearance?
Re: Full Groove vs. 3/4 Groove Mains for BB Mopar [Re: rickseeman] #3223743
03/30/24 03:55 PM
03/30/24 03:55 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I don't have a crank to calculate actual clearance but If I get a crank at nominal diameter than clearance will be .0025-.003( .003 on the center thrust main) . If I base it on the last K1 crank I had(main journals were slightly below min spec) than my clearance will be .0035-.004 (.004 on the center thrust main).
I had a set of full groove Clevite 877P bearings and mounted one in the #1 main to spot check and was pretty much the same.
AG.
Re: Full Groove vs. 3/4 Groove Mains for BB Mopar [Re: AndyF] #3227177
04/15/24 12:20 PM
04/15/24 12:20 PM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
Originally Posted by AndyF
Bearings can be hard to find these days so you should feel lucky that you have a couple of sets to pick from.
I've noticed the same thing, any idea why?
Re: Full Groove vs. 3/4 Groove Mains for BB Mopar [Re: turbobitt] #3227189
04/15/24 12:48 PM
04/15/24 12:48 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
AG.
Taken from the Cleveite bearing catalogue
“The wall is thickest at 90 degrees from the split and drops off a prescribed amount toward each parting line, depending on the bearings intended application. This drop off is called “Eccentricity.” In addition, there is a relief at the parting lines. Eccentricity is used to tailor the bearing shell to its mating hardware and to provide for hardware deflections in operation. Eccentricity also helps to promote oil film formation by providing a wedge shape in the clearance space. The relief at each parting line insures that there will not be a step at the split line due to bearing cap shift or the mating of bearing shells that differ slightly in thickness within allowed tolerance limits”
Its a good read if you want to know bearing specifics..
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Full Groove vs. 3/4 Groove Mains for BB Mopar [Re: W.I.N. Racing] #3227209
04/15/24 01:57 PM
04/15/24 01:57 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
AG.
Thanks but I have already read it and well aware that there is eccentricity built in but was hoping the catalogs would have more specific informataion than just low/medium/high ecentricity....
AG.
Re: Full Groove vs. 3/4 Groove Mains for BB Mopar [Re: LSP] #3227211
04/15/24 02:01 PM
04/15/24 02:01 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
The same old story, global supply chain issues..... The middle east is in turmoil and King bearings is in Jerusalem from what I understand.
I was in contact with king on there +/- ,001 race main bearing sets and they tell me the production date is scheduled for 8/24.
AG/
