Outter wheel well housing’s #3223437
03/28/24 09:13 PM
03/28/24 09:13 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
Need left and right outside wheel well housings for a 1964 Dodge Dart two door. Anyone know if and where I can find these. So far I’m having zero luck web searching.
Re: Outter wheel well housing’s [Re: Dabee] #3223496
03/29/24 08:53 AM
03/29/24 08:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I don't think that is available in the aftermarket which is why you are striking out, good used cut off a parts car or you could patch what you have.
Re: Outter wheel well housing’s [Re: JohnRR] #3223539
03/29/24 12:58 PM
03/29/24 12:58 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
Yea that is what I thought. I was really surprised that I was able to get rear quarter panels for it. Looks like I’ll have to patch the ones in there.
Re: Outter wheel well housing’s [Re: Dabee] #3223573
03/29/24 06:29 PM
03/29/24 06:29 PM
CA
crackedback Offline
crackedback  Offline
CA
Never dealt with him, there is the Robinson guy over at FABO that might have some early A stuff. He parted out a bunch of those over the years.
IIRC, doesn't matter, 2 or 4 door on those parts. All the same, IIRC
Just looked it up, outers are the same for 2dr and 4 dr Darts. No wagons parts.
Re: Outter wheel well housing’s [Re: Dabee] #3223684
03/30/24 11:23 AM
03/30/24 11:23 AM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
I know where there is a 65 and a 66 sitting in a salvage yard for the last 25 years...
Floors have been gone in them since they came in so they're not holding any water... whistling
If you end up needing partial panels from the outer wheel house's to weld back in they may have something on them... shruggy
Could be a good last resort if needed...
...FAFO...
Re: Outter wheel well housing’s [Re: skicker] #3223720
03/30/24 02:14 PM
03/30/24 02:14 PM
Dandridge TN
Dabee Offline OP
Dabee  Offline OP
Dandridge TN
Thanks I’ll look into that if my repair attempt fails. They aren’t really that bad. The lip that the quarter panel attaches to is one on both. I’ll attempt t make a new lip first.
