A body Aftermarket Leaf Spring Shackle Hanger #3223422
03/28/24 08:21 PM
03/28/24 08:21 PM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Hello,
Is anyone aware of a HD aftermarket rear leaf spring shackle hanger for my 68 gts? The stock mounts leave much to be desired.
Re: A body Aftermarket Leaf Spring Shackle Hanger [Re: Jeremiah] #3223669
03/30/24 10:12 AM
03/30/24 10:12 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
You need new OEM equivalent or you want an upgrade to the OEM?
Here's an example of equivalent:
https://www.generalspringkc.com/dodge-plymouth-a-body-leaf-spring-shackle/
Keep old mopars alive.
Re: A body Aftermarket Leaf Spring Shackle Hanger [Re: Jeremiah] #3223686
03/30/24 11:31 AM
03/30/24 11:31 AM
Jamie McGrath Offline
Why not sliders?
Re: A body Aftermarket Leaf Spring Shackle Hanger [Re: Jamie McGrath] #3224622
04/03/24 12:03 AM
04/03/24 12:03 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I have sliders on my other car and prefer them over the OE mounts. I am trying to keep this project to bolt in parts however I might change my mind.
After extensive searching on the net I discovered that Classic industries sells a HD hanger. I will post a picture once they arrive.
Anybpdy have pics of a 68 a body with sliders?
Re: A body Aftermarket Leaf Spring Shackle Hanger [Re: Jeremiah] #3224658
04/03/24 07:54 AM
04/03/24 07:54 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
What's so special about an A-body hanger ??
Re: A body Aftermarket Leaf Spring Shackle Hanger [Re: Stanton] #3224669
04/03/24 09:17 AM
04/03/24 09:17 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
Not a lot really. The rear shackle hanger is pretty wimpy in stock form. My car has a power adder and a manual transmission so it can be hard on things.
Re: A body Aftermarket Leaf Spring Shackle Hanger [Re: Jeremiah] #3224937
04/04/24 08:09 AM
04/04/24 08:09 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Do you use Super stock springs with the sliders? Can you post or send me pics of how you set them up?
eBay-cdwmotorsports
Re: A body Aftermarket Leaf Spring Shackle Hanger [Re: cdwmotorsports] #3224964
04/04/24 10:25 AM
04/04/24 10:25 AM
Rogue River, OR
Jeremiah Offline OP
Jeremiah  Offline OP
Rogue River, OR
I was running the factory HD springs original to the car amd now upgrading to cal tracs and mono leaf springs.
Re: A body Aftermarket Leaf Spring Shackle Hanger [Re: Jeremiah] #3224990
04/04/24 12:11 PM
04/04/24 12:11 PM
moparx Offline
moparx  Offline
if you are talking about the upper shackle hanger that bolts on with two staggered 5/16" [?] bolts, those are pretty easy to fabricate using heavier material than the factory items.
it's been a while since i made some, [many years, actually] but it wasn't a complicated endevour by any stretch of the imagination.
just heavy wall box tube trimmed to shape using the original piece to make a cardboard template, and a heavy wall piece of tube that will fit the bushings.
drill the two mounting holes after shaping the box tube, drill the bushing tube holes, weld in the bushing tube, done.
one hour each if you are old and "half fast" like i am......... biggrin
used to do this quite frequently, as my brother was always buying "darts" [our family's common name for all A bodies] that had crusty upper shackle mounts. [along with crusty rear rails, trunk floors above the mounts, etc. but those stories are for another time. laugh2]
beer
