Re: Flat Tappet Guys
[Re: Kudakidd]
#3223416
03/28/24 07:54 PM
03/28/24 07:54 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I just run the Driven 10-30 Hotrod oil for the last flat solid I had. Before that I was a Brad Penn guy and it was very good too. No failures with either oil and no additive. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Kudakidd]
#3223426
03/28/24 08:36 PM
03/28/24 08:36 PM
Posts: 12,037 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
10w30 VR-1 in my current 540" Hemi for 5 years now. And in my 500" wedge for a decade before that.
No additives, no problems.
Master, again and still
[Re: DaveRS23]
#3223431
03/28/24 08:52 PM
03/28/24 08:52 PM
Posts: 20,510 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Once it's broken in the need for additives is less important. Too much of some types of oil additives, like zddp, can supposedly lead to the metal corrosion as it alters the oil composition. Bob is the Oil Guy is a good site to read up on different types of oil and additives. Some real chemist geeks on there that deep dive into things way over the average person's head. Found this too while reading about camshafts and oil. https://www.nonlintec.com/sprite/oil_myths.pdf
[Re: volaredon]
#3223453
03/28/24 10:27 PM
03/28/24 10:27 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Brad Penn with no issues for 10 years on a Racer Brown solid cam and lifters that are 40 years old from a different long block...
...FAFO...
[Re: Neil]
#3223520
03/29/24 11:04 AM
03/29/24 11:04 AM
Posts: 4,768 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Once it's broken in the need for additives is less important. Too much of some types of oil additives, like zddp, can supposedly lead to the metal corrosion as it alters the oil composition. Bob is the Oil Guy is a good site to read up on different types of oil and additives. Some real chemist geeks on there that deep dive into things way over the average person's head. Found this too while reading about camshafts and oil. https://www.nonlintec.com/sprite/oil_myths.pdf I recently learned the 4.0 Jeep inline 6 was a Hyd Flat tappet engine all the way to its final year of production in 2006. This is a testament that once broken in a higher zinc content is not needed.
Keep old mopars alive.
[Re: Kudakidd]
#3223525
03/29/24 11:33 AM
03/29/24 11:33 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
I used the Driven Hot Rod oil on my last SFT, and Brad Penn on the previous two HFT's. The new SFT that is in there now will also be Driven HOT ROD with no additives after the initial break in.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
