I like it, looks like a nice build.
1969 Plymouth Barracuda notchback Drag car. This Barracuda is titled with a vin. It is currently Registered and insured in the state of Arizona. The chassis is currently certified to 8.50 and the car has been a quick as 8.46 at 160. The spec on the car are as follows:
Engine:
Brand new Hellcat Redeye crate direct from
Dodge
Hell crate control pack
SRT exotic killer package w/ cam upgrade
1400cc fic injectors
2.85 grip Tec upper pulley
Ati 10% over lower damper
1” blower spacers
SDG trifecta package
Ported blower, upgraded snout and 108mm throttle body,
Holley oil pan with diaper
Tuned by Zhtunes
Runs on e85 ONE R
Have a 91 tune for it for drag and drive events for cruising
Full aeromotive fuel system
10 gallon pnr ice tank for supercharger
Transmission:
Ati gen3 Hemi t400
Ati sfi aluminum case
Custom flex plate and adapter
Sfi mopar bellhousing
Compu-flow reverse manual transbrake
Roller bearing tail housing
Deep aluminum pan
Located locking dipstick
Circle d custom converter
M&M ratchet shifter (setup for air shifting)
Trans catch can
Rearend”
Fab 9 rear end
Strange engineering pro gear 3.89 third member
40 spline gun drilled axles
Spool
4 link with wish bone
Qa1 mod rear coil overs
Wilwood rear disc brakes
Chassis
Full back half car
Rectangle rear frame rails and subframe
All new floor
Factory front frame rails still in place
Double a arm front suspension with manual rack and pinion
Strange front drag brakes
Rear anti roll bar
Removable tunnel
Wheelie bars
Rjs parachute
Funny car cage with window net w/ 8.50 cert
Race quip seats and harnesses (have matching drivers harness new in box)
Carbon fiber dash
Carbon auto meter gauges
Aluminum tin work with mopar logo thru out
Plexi side windows. Glass front and rear
Single odyssey battery
Removable steering wheel
Line lock
Ron Francis body harness with painless switches
15x14 RC component beadlock wheels
17x4.5 Rc component front wheels
Mickey Thompson et street bias ply 32x14-15
Mickey Thompson et street front 26x6-17
Body:
Original 69 barracuda body
Fiberglass tilt front clip and deck lid.
Steel doors
Dzus fasteners
Fender exit exhaust
This is a turn key drag car that can been street driven at your discretion. It have driven it up and down the freeway several times. Would make an excellent drag and drive setup. This car was the winner of the 2023 roadkill nights influencer challenge and also competeted in the 2022 event as well. It is very dialed and and is a easy car for anyone looking to hop into an 8 second car. Passes nhra tech without any issues and is extremely safe. Comes with some extras such as a new set of slicks (currently on a full dot setup for certain events). The car has seen several liveries over the past fuel years and can be put back to any which one or left all white for the buyer. I have a tremendous amount of build pictures as well as video. Feel free to reach out with any questions. I would consider selling the car minus engine and controller for 15k less. Asking $75,000 obo
