Re: New cast iron Hemi block
[Re: cudaman1969]
#3222724
03/25/24 05:12 PM
03/25/24 05:12 PM
Posts: 5,108 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
Callies iron blocks just google them and see what bores they have. FHO has used a few for customers that wanted an iron block. I have see a few for sale on mopar sites and ebay just take a look around.
1971 HEMI E BODY REGISTRY
[Re: fbs63]
#3222848
03/26/24 09:51 AM
03/26/24 09:51 AM
Posts: 8,271 fredericksburg,va
cudaman1969
fredericksburg,va
I understand that a new Hemi block is a large purchase. Why would you spend $5500-6000 for an iron block when you can get an aluminum one for $1500 more? Repairable and 150 lbs lighter. Because it will be street only and I don’t want a block that ‘moves’ around in the cold to hot cycle and please don’t say aluminum won’t grow. Besides it’ll look dumb with cast iron heads.
[Re: cudaman1969]
#3222854
03/26/24 10:35 AM
03/26/24 10:35 AM
Posts: 2,650 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Surely one of the vendors will have a Callies block. 4.25 bore might be harder though. I assume they mainly sell 4.500. But I don't know that.
2011 Drag Pak Challenger
[Re: rickseeman]
#3222869
03/26/24 11:53 AM
03/26/24 11:53 AM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Paint bock orange....Absolutely NO reason to not run an aluminum block on the street. good luck finding a 4.25" bore, only one who MIGHT be close is Jason Lines stuff but it comes with other things you likely wont need for a street car like a 60MM cam.
[Re: cudaman1969]
#3224813
04/03/24 05:37 PM
04/03/24 05:37 PM
Posts: 10,005 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I understand that a new Hemi block is a large purchase. Why would you spend $5500-6000 for an iron block when you can get an aluminum one for $1500 more? Repairable and 150 lbs lighter. Because it will be street only and I don’t want a block that ‘moves’ around in the cold to hot cycle and please don’t say aluminum won’t grow. Besides it’ll look dumb with cast iron heads. Paint and headers hide a lot of sin😁 Besides, aluminum requires some extra care, bur it isn't unworkable. Run a bit tighter main bearing clearance, expect .008 to .010 deck hieght growth, and i would go aluminum heads as well if you can budget for it. Now you have a kller hemroid, and about 150 lbs less up front!
[Re: cudaman1969]
#3224817
04/03/24 05:54 PM
04/03/24 05:54 PM
Posts: 12,391 Taxes & Virus's R-US, NY
Dragula
I have a slightly used one here I bought from Callies, some time ago....I might let it go, but its not free....I actually have two, one is a complete engine that could go for the right price as well.
[Re: Dragula]
#3225090
04/04/24 07:46 PM
04/04/24 07:46 PM
Posts: 657 Berlin NJ
scottk
Berlin NJ
I have a slightly used one here I bought from Callies, some time ago....I might let it go, but its not free....I actually have two, one is a complete engine that could go for the right price as well. I would be interested if cudman passes.
[Re: Al_Alguire]
#3225321
04/05/24 11:33 PM
04/05/24 11:33 PM
Posts: 3,395 Pa
Hot 340
Pa
Paint bock orange....Absolutely NO reason to not run an aluminum block on the street. good luck finding a 4.25" bore, only one who MIGHT be close is Jason Lines stuff but it comes with other things you likely wont need for a street car like a 60MM cam. Can you tell us how much street driving you did with your aluminum hemi block? And which block was it?
[Re: Al_Alguire]
#3225371
04/06/24 09:56 AM
04/06/24 09:56 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
Paint bock orange....Absolutely NO reason to not run an aluminum block on the street. good luck finding a 4.25" bore, only one who MIGHT be close is Jason Lines stuff but it comes with other things you likely wont need for a street car like a 60MM cam. Painted mine orange because I wanted that kind of stock look since Istreet drive it , but a race car at the same time. Also running a 60mm as well.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
