Howard's 360 Magnum hydraulic roller 770055-12 #3222763
03/25/24 07:32 PM
03/25/24 07:32 PM
Canada
CrAzYMoPaRGuY Offline OP
Canada
Does anybody know if Howard's Cams hydraulic roller small block cams are "long snout", as in CAN have a mechanical fuel pump eccentric bolted up??
I phoned Howard's, the guy on the line could only say it "didn't have a fuel pump lobe". I asked if long snout so it could ACCEPT a fuel pump lobe, and he didn't know.
Anybody run a small block Magnum motor with a Howard's hydraulic roller with a mechanical fuel pump?? It the 770055-12 cam I'm looking at
THANKS!!!
CrAzYMoPaRGuY
Re: Howard's 360 Magnum hydraulic roller 770055-12 [Re: CrAzYMoPaRGuY] #3222888
03/26/24 01:08 PM
03/26/24 01:08 PM
Canada
Canada
So for anybody wondering in the future-
Howard's cams small block Magnum hydraulic roller cams are all SHORT SNOUT cams, no fuel pump eccentric provisions. Howards can make an identical ground cam in an LA engine configuration (long snout) as a custom ground camshaft.
CrAzYMoPaRGuY
Re: Howard's 360 Magnum hydraulic roller 770055-12 [Re: CrAzYMoPaRGuY] #3222937
03/26/24 05:13 PM
03/26/24 05:13 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I think you have the wrong series part numbers that start with 71 are the retro fit ones shruggy
Re: Howard's 360 Magnum hydraulic roller 770055-12 [Re: B1MAXX] #3222948
03/26/24 05:43 PM
03/26/24 05:43 PM
Canada
Canada
Yup retro fit is long snout. None available (OF COURSE!)
CrAzYMoPaRGuY
Re: Howard's 360 Magnum hydraulic roller 770055-12 [Re: CrAzYMoPaRGuY] #3223026
03/27/24 02:14 AM
03/27/24 02:14 AM
Canada
Canada
Little bit of digging....
https://www.hughesengines.com/Index...ENoYWluICYgQ29tcG9uZW50&partid=22194
For the next guy.....lol
CrAzYMoPaRGuY
