Hemi valve cover removal #3222744
03/25/24 06:16 PM
03/25/24 06:16 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
I'm trying to remove the drivers side valve cover on my 528 hemi, but it doesn't seem to want to slide over the spark plug tubes. Do these have to be removed to get the valve cover off? I don't want to force anything a damage something. The gasket is not sticking to the cover, I can wiggle it around, but it doesn't want to slide off of the cylinder head.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: Hemi valve cover removal [Re: 73cuda340] #3222749
03/25/24 06:29 PM
03/25/24 06:29 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Yes. You have to remove the spark plugs and the tubes will come out.
Re: Hemi valve cover removal [Re: fastmark] #3222752
03/25/24 06:39 PM
03/25/24 06:39 PM
clarks summit pa
clarks summit pa
Just got it off, thanks alot
