Slotted hex nuts #3222529
03/24/24 12:52 PM
03/24/24 12:52 PM
Detroit area
6PAX Online content OP
6PAX  Online Content OP
Detroit area
I have two idler arms with bolts. The slotted nut on one of them has 6 slots, the other one has 3 wider slots. Been trying to find the difference between them (other than the obvious number of slots) but can only find information on the 6 slot nuts. Can someone clarify what the difference is (again, other than the number of slots) and what applications they were typically used on?
Re: Slotted hex nuts [Re: 6PAX] #3222530
03/24/24 12:54 PM
03/24/24 12:54 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
As a general rule, 3 slots is OEM. 6 slots is aftermkt and usually plated bright zinc, OE was dark phosphate
All the OEM idler arm, pitman arm and tie rod nuts were 3 slotted As far as Im aware
PS, I think a lot of the OEM lower ball joint to backing plate nuts were 6 slot but dark phosphate plated
Re: Slotted hex nuts [Re: gtx6970] #3222537
03/24/24 01:34 PM
03/24/24 01:34 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
They are called castellated nuts
Re: Slotted hex nuts [Re: Sniper] #3222558
03/24/24 03:39 PM
03/24/24 03:39 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You can still buy the OEM nuts from AMK Fasteners https://www.amkproducts.com/bulk-fasteners-products/?Product_ID=11486
Gus beer
64 Plymouth Savoy
Dana 60
Re: Slotted hex nuts [Re: fourgearsavoy] #3222624
03/25/24 12:33 AM
03/25/24 12:33 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Gus beer
AMK offers 1/2", 9/16", and 5/8", but not 7/16".
Re: Slotted hex nuts [Re: kentj340] #3222662
03/25/24 11:31 AM
03/25/24 11:31 AM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Check Fastenal.
Re: Slotted hex nuts [Re: gtx6970] #3222668
03/25/24 12:15 PM
03/25/24 12:15 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Factory used both.
Re: Slotted hex nuts [Re: John_Kunkel] #3222672
03/25/24 12:22 PM
03/25/24 12:22 PM
It's a dry heat
It's a dry heat
Factory used both.
That literature may show that.
But show me an original car with 6 slot nut ,,, other than what the I mentioned
Re: Slotted hex nuts [Re: gtx6970] #3222753
03/25/24 06:44 PM
03/25/24 06:44 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've found both styles on original cars.
Doug
