Dual brake system necessary part #3222314
03/23/24 10:14 AM
03/23/24 10:14 AM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Here is the best picture of a "proportioning valve" I have seen. This is the valve necessary to give you the dual brake system "cut off the leaking side" brakes.
Re: Dual brake system necessary part [Re: SportF] #3222345
03/23/24 12:50 PM
03/23/24 12:50 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That is not a proportioning vale. It is a combination valve. One of it's functions is proportioning.
The cut off the leaky side function isn't it's main purpose.
It's main purpose is to mitigate the functional differences between disc and drum brakes.
Re: Dual brake system necessary part [Re: Sniper] #3222365
03/23/24 02:15 PM
03/23/24 02:15 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Note that I put "proportional" in quotes.
How does it differentiate there?
Re: Dual brake system necessary part [Re: SportF] #3222370
03/23/24 02:35 PM
03/23/24 02:35 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Missed the intent of the quotes, lol, sorry.
Not sure what your question is though
Re: Dual brake system necessary part [Re: SportF] #3222435
03/23/24 10:55 PM
03/23/24 10:55 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
it differentiates in that is serves two purposes.
1. Being a cut off valve as mentioned.
2. Providing a "PRESET" amount of proportioning or delay to the rear brakes.
There are valves that do one or the other A. bypass valve for isolating the leaking side. B. Proportioning valve for delaying application of the rear brakes.
The pictured valve does both, hence the term "Combination valve". These types of valves are typically non- adjustable so one has to be careful when selecting them as they may or may not work as desired in a modified braking system depending on a bunch of other variables.
beer
Re: Dual brake system necessary part [Re: SportF] #3222468
03/24/24 08:25 AM
03/24/24 08:25 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Wrong.
A dual circuit master cylinder is what's necessary. Any other valves are for fine tuning. There's numerous OEM applications that are plumbed with the front brakes straight to the master and rear brakes may have a proportioning valve or an ABS valve.
Angry white pureblood male
Re: Dual brake system necessary part [Re: ruderunner] #3222475
03/24/24 09:08 AM
03/24/24 09:08 AM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Go to your car without a valve and open a bleeder. The pedal is going to go to the floor. Period. I wanted to stir things up, which I why I posted.
But, I doubt I can change your mind. Last summer, two different tracks, two "dual" masters, brake leak and pedal goes to floor because, no valve. Both mopar type masters.
Also, there is no delay in rear brake apply. The proportion part is a set pressure regulator limiting pressure to rear to prevent lockup.
I'm done, have a nice day.
Re: Dual brake system necessary part [Re: SportF] #3222495
03/24/24 10:52 AM
03/24/24 10:52 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Is this a race car?
Street car, the brake warning light may need to be functional and all the parts there to pass inspection. Otherwise, it's not used on race cars. Not much chance of rusted brake lines or old hoses blowing out.
Design the system correctly, use the right parts, plumb it correctly, and you likely won't need any kind of band aid valve.
Re: Dual brake system necessary part [Re: SportF] #3222496
03/24/24 10:54 AM
03/24/24 10:54 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
There most assured is a delay, but it is to the discs. It's called hold off.
Then there is hinge point where the rate of pressure increase to the drums is slowed due to the self energizing function of modern drum brakes.
And the aforementioned proportioning.
What trucks are you talking about?
Re: Dual brake system necessary part [Re: SportF] #3222531
03/24/24 01:10 PM
03/24/24 01:10 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I've been in plenty of vehicles with blown brake lines here in Ohio. So, I've played your game. Yes the pedal has extra travel but, one half of the brake system still works.
So here's a challenge to you. Disconnect a line at the master and plug the port. Your pedal may feel ok, but you're still only operating half the brakes.
