Re: Beehive spring hemi valve cover clearance?
[Re: Craig J]
#3222379
03/23/24 04:58 PM
03/23/24 04:58 PM
Posts: 2,637 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I really struggle with the search function, so I apologize if this was already discussed.
On a Victor Jr. Hemi head I think the exhaust valve is rotated slightly to allow a larger intake valve. Is that correct?
If true, then the valve & rocker arm are closer to hitting a stock valve cover?
A good friend of mine told me that he believes a beehive spring & the much smaller retainer will prevent the retainer from hitting the valve cover, is that correct?
Thanks Craig I've built a few motors with Victor Jrs and 1.55" regular springs and haven't had a problem. And I don't think anyone else has either.
2011 Drag Pak Challenger
[Re: rickseeman]
#3222579
03/24/24 05:40 PM
03/24/24 05:40 PM
Posts: 166 West Palm Beach, Florida
Craig J
Thanks Craig I've built a few motors with Victor Jrs and 1.55" regular springs and haven't had a problem. And I don't think anyone else has either. Thank you Rick. I have a set of heads on order at Summit... maybe they will ship this year. Side note: Please keep posting youtube videos of your KB engine assembly, I really enjoy them. Craig
[Re: Craig J]
#3222588
03/24/24 07:25 PM
03/24/24 07:25 PM
rickseeman
Stuttgart, Arkansas
The way I look at it is that it moves the spring away from where it normally hits the valve covers. Which beehives on their own should eliminate the problem of the spring/retainer hitting the valve covers.
