help with wiring harness part number #322224
05/18/09 09:45 PM
05/18/09 09:45 PM
MOORESVILLE NC
69four46 Offline OP
69four46  Offline OP
MOORESVILLE NC
I recenetly purchased some NOS parts and one in particular has me puzzled. I can't find the part number in any of my books or cd's. It may be a fog light harness the box reads as follows 1#3513-097 and inside there is the harness and a #2889916 relay any help would be greatly appreciated.
Re: help with wiring harness part number [Re: 69four46] #322225
05/18/09 10:13 PM
05/18/09 10:13 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
If no one knows you might want to contact Evans they might know:
http://evanswiring.tripod.com/id2.html
Re: help with wiring harness part number [Re: 69Cuda340S] #322226
05/18/09 10:23 PM
05/18/09 10:23 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
P/N 3513097 Wiring, Window Lift Safety Relay
Up To Jan. 1971 B-Body
P/N 3004186 Relay, 70 Cuda Road lamp and 70 B-Body Window lift
Re: help with wiring harness part number [Re: Snoopy] #322227
05/19/09 06:45 AM
05/19/09 06:45 AM
MOORESVILLE NC
69four46 Offline OP
69four46  Offline OP
MOORESVILLE NC
The relay is exactly the same I have attached a photo of the harness. Looks like a road lamp harness
Re: help with wiring harness part number [Re: 69four46] #322228
05/19/09 03:18 PM
05/19/09 03:18 PM
Snoopy Offline
Snoopy  Offline
The road lamp harness is part number 2983711. You have a 70 B-Body window lift wiring harness.
Here is a 70 road lamp harness.
Re: help with wiring harness part number [Re: Snoopy] #322229
05/19/09 05:19 PM
05/19/09 05:19 PM
MOORESVILLE NC
69four46 Offline OP
69four46  Offline OP
MOORESVILLE NC
But the relay is the same # used for the road lamps correct?
Re: help with wiring harness part number [Re: 69four46] #322230
05/19/09 08:58 PM
05/19/09 08:58 PM
Snoopy Offline
Snoopy  Offline
Same relay, different wiring harness.
