TPS censors for carbs. #3219884
03/12/24 06:16 AM
03/12/24 06:16 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Anybody here run them?
I'm looking to upgrade a fuel system with the Aeromotive 5.0 brushless variable speed pump, it come with a 3-wire hookup. The third wire is for a throttle body censor.
My question how does the carb censor gets wired? I'm using a MSD digital 6 for now but will be upgrading to a 7.....Thx coffee
Re: Throttle body censors for carbs. [Re: racerx] #3219885
03/12/24 07:16 AM
03/12/24 07:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My bet is it needs a tps bolted to the linkage. Probably a GM sensor. The three wires are 5 volt feed, reference,and ground. This way the pump will increase volume with throttle opening. Also assuming fuel pressure should be set with the throttle lever at wot.
Doug
Re: Throttle body censors for carbs. [Re: dvw] #3220366
03/14/24 10:33 AM
03/14/24 10:33 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Doug
Thxs Doug coffee Been researching this and found out that Holley actually sells a TPS for the 4500 series carbs. Reading though some of the commits on the tube someone mentioned DWM any ideal what that stands for? work
Re: Throttle body censors for carbs. [Re: racerx] #3220382
03/14/24 12:13 PM
03/14/24 12:13 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
We run them on our Off Road Truck Racing Series engines that require carbs. However, we use all Motec electronics and software. It is a RG.SN.3051 part # if this TPS will work for you.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Throttle body censors for carbs. [Re: 6PKRTSE] #3220421
03/14/24 02:30 PM
03/14/24 02:30 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
The Gen 3 Ultra Dominators have the provision for a TPS. We use it for a Racepak, no reason why it couldn't be used on other carbs with a little fab work / or modification.
https://documents.holley.com/199r10624rev.pdf
Edit: Looking at the instructions I'd be tempted to run it with a micro switch for full demand when the throttle is opened to a % position of your choice. It looks like it needs a 0 - 5 V signal to get the full variable speed mode, but anything over 3.7V's it runs at full speed anyway.
https://prod-da.s3.us-east-2.amazonaws.com/BHKJ/07742b772ad557f0b01ab640e6a80905.pdf
Re: TPS censors for carbs. [Re: racerx] #3220767
03/16/24 10:04 AM
03/16/24 10:04 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I've been eyeballing these for a long time since for my DIY carb tuning efforts this would be a great data point to have.
What I've learned so far is this: while the well known aftermarket vendors for the most part can provide you with a nearly "bolt-on" setup, unless you have to do so I would recommend eBag shopping...most of these sensors are pretty generic and they can be had for literally $10-15...so if you have to make your own mounting brackets it just makes sense to save a boat-load of cash in taking that approach.
Search eBay for the following item ID 156108911635, it literally appears to be the very same switch: 'GM part # 17112679 TPS'.
Re: TPS censors for carbs. [Re: racerx] #3220830
03/16/24 02:21 PM
03/16/24 02:21 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Yes I do...I have one of the newer Holley Dom's that has provisions for one and I wired it into my stand alone dash. Works well, and I trigger the data logger off of it at 80% throttle...
https://www.jegs.com/i/Holley/510/9920-110/10002/-1
Re: TPS censors for carbs. [Re: Dragula] #3221613
03/20/24 09:54 AM
03/20/24 09:54 AM
Connecticut
FurryStump Online content
FurryStump  Online Content
Connecticut
I bought a throttle position sensor for a 350Z and mounted it to the stock pedal. The stock arm of the pedal rotates the sensor. $35? This is an A body
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: TPS censors for carbs. [Re: FurryStump] #3222092
03/22/24 11:44 AM
03/22/24 11:44 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
WWHHHAAAATTTTT????
That's excellent setup...pics please!!!
Re: TPS censors for carbs. [Re: Diplomat360] #3222119
03/22/24 01:08 PM
03/22/24 01:08 PM
GA
roadrunninMark Offline
GA
I would like to see this as well! Does it matter what year 350z tps?
Re: TPS censors for carbs. [Re: roadrunninMark] #3222138
03/22/24 01:58 PM
03/22/24 01:58 PM
Connecticut
Connecticut
Let me look for pictures of it installed.
Re: TPS censors for carbs. [Re: FurryStump] #3222146
03/22/24 02:18 PM
03/22/24 02:18 PM
Connecticut
Connecticut
Here it is. Been on the car for a couple of years?
Re: TPS censors for carbs. [Re: FurryStump] #3222149
03/22/24 02:42 PM
03/22/24 02:42 PM
Connecticut
Connecticut
The green trace is it, it is not linear, but it showed me what I wanted to know. You could build a compensation thing in your channel configuration.
Re: TPS censors for carbs. [Re: FurryStump] #3222174
03/22/24 04:17 PM
03/22/24 04:17 PM
GA
GA
Did you have to do any figuring for the amount of peddle arc to open the tps all the way vs. the peddle all the way to the floor? Or did full peddle equal full opening of the tps?
Re: TPS censors for carbs. [Re: roadrunninMark] #3222185
03/22/24 04:59 PM
03/22/24 04:59 PM
Connecticut
Connecticut
Did it through the logging software. Watched what volt value it showed at idle and watched what it showed at full throttle. Then made those voltages o% and 100%. Some will just self learn.
Re: TPS censors for carbs. [Re: FurryStump] #3222234
03/22/24 07:35 PM
03/22/24 07:35 PM
GA
GA
I m not familiar with logging software, I assume the computer that needs the TPS input is where you could do the setting for it? I will be using a TPS for a 8 speed trans install so I assume that the controller will be where that would be done?
Re: TPS censors for carbs. [Re: FurryStump] #3222289
03/23/24 06:16 AM
03/23/24 06:16 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thxs for the info. up ? those pictures you posted on the TPS is six wire/pins and most of the one i see are the three wire .Do you wire in all six of them into your system?
Re: TPS censors for carbs. [Re: racerx] #3222291
03/23/24 07:12 AM
03/23/24 07:12 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
OK. As far as I can tell the pump achieves full speed (100%) @ 3.7V and min speed (25%) @ 0.5V which means it has a resolution of 25- 100% speed in 3.2 V.
You will need a 5V supply to achieve the best control. Otherwise, if you will be using a 12v supply, aprox only 25% of full TPs movement will give you 25 to 100% speed control and it's likely to be nearer 20% movement once the alternator is running. So pretty much like an on/off switch anyway.
If you just require the TPS to control the pump you can't get much easier than what Aeromotive recommend using a simple micro switch. Again the "on" (100% speed position) can be set to wherever you feel comfortable with throttle wise.
Re: TPS censors for carbs. [Re: Tig] #3222294
03/23/24 07:37 AM
03/23/24 07:37 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thxs coffeea key part in this is a micro switch. up
Re: TPS censors for carbs. [Re: racerx] #3222297
03/23/24 08:13 AM
03/23/24 08:13 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Are you using a 5.0 pump ? it's listed as FI only ? If you are going FI it's a different ball game entirely.
