First Dana #3221940
03/21/24 05:31 PM
03/21/24 05:31 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Putting a new carrier and gears in my dana. I'm trying to figure out how much CARRIER preload I need and there is very little info out there on it. I spread my case with the spreader .015, and simply could not get the new carrier in there with shim stacks from old carrier. (I made setup bearings as well) So, is it acceptable to make it a snug fit with the case spread .015 and when the spreader is removed will that provide enough? Thanks...
Re: First Dana [Re: Hot 340] #3221953
03/21/24 06:43 PM
03/21/24 06:43 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
More than enough. I usually put the shims in and start the carrier with bearings and rubber mallet it home. That's way less than .015.
Re: First Dana [Re: B1MAXX] #3221971
03/21/24 07:46 PM
03/21/24 07:46 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I never use a spreader. Fit it and set backlash with a mild tap in. Then add .005" to each side.
Doug
Re: First Dana [Re: dvw] #3222043
03/22/24 07:11 AM
03/22/24 07:11 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Doug
Exactly what I do also.
Re: First Dana [Re: fbs63] #3222082
03/22/24 10:34 AM
03/22/24 10:34 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thanks guys!
Re: First Dana [Re: Hot 340] #3222113
03/22/24 12:28 PM
03/22/24 12:28 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I remember my first Dana. She was a wonderful girl and probably should have been a keeper.
The second Dana was an absolute train wreck and a crazy woman.
Oh, you guys were referring to rear ends..... I have several of those also and like mentioned above, never needed a spreader.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
