6.4 cab and chassis engine #3221993
03/21/24 08:59 PM
03/21/24 08:59 PM
montana
BANDIT Online content OP
BANDIT  Online Content OP
montana
Does anyone know what the difference is between a 6.4 out of a 2014 2500 pickup vs a 6.4 out of a 2014 3500 cab and chassis? thanks, Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: 6.4 cab and chassis engine [Re: BANDIT] #3222021
03/21/24 10:51 PM
03/21/24 10:51 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
They're the same engine. Both are BGE blocks. The cab/chassis engine might be a lower hp "rating" , but that's just limiting the rpm for the Aisin trans
Re: 6.4 cab and chassis engine [Re: WO23Coronet] #3222023
03/21/24 11:10 PM
03/21/24 11:10 PM
montana
montana
IT does show a different part number in reman catalogs, and most are weeks out when trying to order one. The truck does have Aisan trans tho.
4600 DA
Re: 6.4 cab and chassis engine [Re: BANDIT] #3222101
03/22/24 12:05 PM
03/22/24 12:05 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I think they didn't have MDS and RPM was limited. They are the same heads, pistons, block... Put it in a normal 2500 or something and it will run just the same but no MDS.
