SB turbo guys, how much pressure and HP Wefi #3221345
03/19/24 03:18 AM
03/19/24 03:18 AM
Cab_Burge Offline OP
I'm getting ready to start buying parts and assembling a SB 360 motor with a offset ground crank that I think has right at 3.75 stroke and the bore will be the minimum size needed to straighten out the bores, I'm not going all out for max power on this build.
It will be in a 1965 Valeant 200 Signet with a Pro Trans 904 and probably a 35 spline Dana 60 pickup housing cut down and made for this deal with leaf springs, I will run it on the local E85 pump swill so I hopefully won't have to wory about detonation running the turbo boost up to 10 Lbs. or less using one of Holley's EFI direct port injection, not throttle body injectors.
I'm planning on using this car to learn EFI programming and data storage and use it for tuning this motor luck grin
My questions are anyone else using E85 with a SB turbo motor on here help
What mechanical compression ratio and cam specs information would be very helpful help luck
Thanks in advance: bow Cab
Re: SB turbo guys, how much pressure and HP Wefi [Re: Cab_Burge] #3221482
03/19/24 04:56 PM
03/19/24 04:56 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Not a small block, but I do run pump E-85 with boost. I quit checking it as it was always at least 80% alcohol. I have a 470 with a measured 10.0:1 compression ratio. Home ported Edelbrock R.P.M. heads. Holley Sniper X-flow. Cam is a Bullet s.f.t. 247in.251 ex @.050",.546-.540 lift with a 115 lobe sep. angle. Bought it from Little john motorsports after sending them all the info on the combo and intended use. I looked up the lobes in their catalog and it actually has a Ford .875 intake lobe and a Chevy .842 exhaust lobe. Told them this is a 100% streetcar and didn't need anything that would beat up the valvetrain for 4 extra h.p.. In. opens 12.5 closes 54.5 . Ex. opens 64.5 closes 6.5. I run it at around 12 lbs with timing in the low 20's. I have had it as high as 17 lbs., but don't need that much extra tire wear.
Re: SB turbo guys, how much pressure and HP Wefi [Re: 67_Satellite] #3221499
03/19/24 06:19 PM
03/19/24 06:19 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Cab, I suggest contacting Dizuster or DVW here - Dizuster's '62 Savoy was stupid-fast with basic parts.
Or maybe they'll see this & post.
Re: SB turbo guys, how much pressure and HP Wefi [Re: Cab_Burge] #3221527
03/19/24 08:07 PM
03/19/24 08:07 PM
West Palm Beach, Florida
Craig J Offline
Craig J  Offline
you could copy the recipe used by thousands of sloppy mechanics on 6.0 LS engines and pump E85... conservative timing, single 78/75 VS turbo, holley terminator, 15 psi boost. they typically produce 150 mph trap speed @ 3000 lbs in random crappy fox body cars. I don't see why the same concept would not work on a 5.9 magnum stroker. The "sloppy stage 2" cam from Elgin is commonly used.
