Stock Oil pan from 64-66 #3221267
03/18/24 05:55 PM
03/18/24 05:55 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
I picked up a 66 383 for the heads and pan. Will that 66 pan fit the 65 K-frame? I had brain fade thinking again but I do know the 66 and up used a different k and engine sits back more but..
Paid $100 for engine but when pulling it down found #8 rod cap was in pan in a weird shape lol needless to say crank-block-piston no good so I’ll use the 413 shortblock now with the 516 heads.
Re: Stock Oil pan from 64-66 [Re: cudaman1969] #3221330
03/18/24 10:17 PM
03/18/24 10:17 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
not sure on the pan but i do recall chasing my tail on a noise that appeared after swapping another 440 into my Mom's 65. Finally discovered a small mark inside the oil pan from either a rod, rod bolt or crank throw. whistling mad
Re: Stock Oil pan from 64-66 [Re: TJP] #3221413
03/19/24 12:23 PM
03/19/24 12:23 PM
moparx Offline
moparx  Offline
i have a pan from a 64 300, but i don't know if that will fit.
beer
Re: Stock Oil pan from 64-66 [Re: cudaman1969] #3221447
03/19/24 02:28 PM
03/19/24 02:28 PM
Early,1966 to 1969, Street Hemi oil pans will fit but they hang down past the K member, same thing on the early C bodies but they don't come with slosh and acceleration baffles shruggy
I have made my own baffles and added them on hose oil pans a lot of times work scope wrench up
Re: Stock Oil pan from 64-66 [Re: cudaman1969] #3221452
03/19/24 02:39 PM
03/19/24 02:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The '62-'65 B-body engine sits 1 5/8" further forward than the '66-later. This makes the front of later pans interfere with the early K-member.
Re: Stock Oil pan from 64-66 [Re: John_Kunkel] #3221453
03/19/24 02:54 PM
03/19/24 02:54 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I ran a 66 440 in my 65 for like 30 years with a 66 pan that came on the 440 Never a problem.Now the 440 has a 8 qt Moroso pan that is listed 66 up.Fits great I did take a tiny notch from the K frame for more clearance Didndt have to but just made me feel better Oh yeah driven on the street with the 8 qt for 20 years now and never a problem.
Chrysler Firepower
Re: Stock Oil pan from 64-66 [Re: therocks] #3221492
03/19/24 05:34 PM
03/19/24 05:34 PM
fredericksburg,va
fredericksburg,va
If I do this I’ll cut the pan I guess, wait..
