What heat range plugs?
#3220526
03/14/24 11:41 PM
03/14/24 11:41 PM
Posts: 46 Medford, OR
carrman
Medford, OR
I've got a 440 with Stealth heads. Compression is about 8.2:1 as it's a late '72 engine form an RV, but does have a forged crank. I running a Lunati roller cam with these specs:
Advertised Intake Duration: 270 Advertised Exhaust Duration: 278 Intake Duration at .050 Inch Lift: 219 Exhaust Duration at .050 Inch Lift: 227 Intake Valve Lift: 0.515 Exhaust Valve Lift: 0.530 Lobe Separation: 110 Intake Center line: 116
Running an FBO electronic ignition with one of their custom curved distributors tailored to this cam. My question is this, what heat range plugs should I be running? I use NGK and prefer to stick to these. The car is a heavy Newport convertible I use as a cruiser and freeway runner. Any suggestions?
Re: What heat range plugs?
[Re: carrman]
#3220745
03/16/24 01:57 AM
03/16/24 01:57 AM
Posts: 43,205 Bend,OR USA
Cab_Burge
Do you have a picture of one, hopefully #7? Autolite # 3924 should be a 3/4 reach plug with a 5/8 socket size, not correct for stock iron heads I am breaking a pump gas iron headed motor now for a local customer, I put a set of Champion RJ86Y in it I was hoping to find some Champion RJ12YC or maybe even some RJ14YC or RJ10YC but no hope in my current stock
[Re: carrman]
#3220882
03/16/24 06:46 PM
03/16/24 06:46 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
With that low of compression 8.2-1
NGK 7938 - BKR5E
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: carrman]
#3221165
03/18/24 02:08 AM
03/18/24 02:08 AM
Cab_Burge
Do you know how cold the # 11 are ? Probably work great in a high compression blown or turbo charged motor with 12+ lbs. of boost on gasoline
[Re: carrman]
#3221343
03/19/24 02:59 AM
03/19/24 02:59 AM
Cab_Burge
BKR6E-11 Are what I have in there now, they are one heat range colder than the ones I want to put in.
Dave Is the 6# or the 11# the heat range on hose plugs. I don't use NGK, Autolites or Champions for me
[Re: Cab_Burge]
#3221379
03/19/24 10:11 AM
03/19/24 10:11 AM
Posts: 148 Albert Lea, MN
GTX5877
Albert Lea, MN
The #6 is the heat range and the 11 is the gap. #5 would be one step hotter
1967 Dart GTS 426 Gen III Hemi 1968 Hemi Cuda 572 SS/AH Clone 1988 Chrysler LeBaron Coupe S/S 2003 Dodge Ram 1500 4dr SLT lowered 2012 Ram 1500 2wd Lowered 1970-1/2 Camaro Z-28 1974 VW Karman-Ghia
