Ready, Fire, Aim... #3220697
03/15/24 08:15 PM
03/15/24 08:15 PM
West Palm Beach, Florida
Craig J Offline OP
Craig J  Offline OP
Please tell me this will work with an e body standard shaker hood.
Re: Ready, Fire, Aim... [Re: Craig J] #3220707
03/15/24 08:59 PM
03/15/24 08:59 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It would help to see the intake out of the box.
Re: Ready, Fire, Aim... [Re: Craig J] #3220715
03/15/24 09:36 PM
03/15/24 09:36 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
It's possible the fuel inlet hoses are too high up too far away from the carburetor inlets so the air cleaner base may contact the hoses?
Looking around it appears the fuel lines from the factory setup drop down sooner than what you have there.
https://www.moparaction.com/2020/01/15/1971-hemi-engine-detailing/
Re: Ready, Fire, Aim... [Re: Craig J] #3220723
03/15/24 10:11 PM
03/15/24 10:11 PM
The stock street hemi fuel lines are bent down coming out of the carb fitting to clear the air cleaners (and shakers) on all 6 years of them in both B and E body, not so in 1968 A bodies with the race hemis grin
Re: Ready, Fire, Aim... [Re: Cab_Burge] #3220748
03/16/24 05:31 AM
03/16/24 05:31 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Aren't there different airhorn diameters too? IIRC earlier AFB were smaller than the current products.
Angry white pureblood male
Re: Ready, Fire, Aim... [Re: Craig J] #3220793
03/16/24 12:11 PM
03/16/24 12:11 PM
central il.
second 70 Offline
second 70  Offline
central il.
Nope that won't work. You need the 90 degree fittings. Factory had a brass 90 threaded into the carbs and lines went straight up.
