Mopar Perf Racing Voltage Regulator #3220668
03/15/24 05:17 PM
03/15/24 05:17 PM
Pennsylvania
19_Dart_68 Offline OP
Pennsylvania
Hi all,
Is there a particular reason why this regulator is listed as drag race only? Is it a potential hazard, in some form, if used on a street-driven car?
68 Dart - 440 Swap in Progress...please stand by
Re: Mopar Perf Racing Voltage Regulator [Re: 19_Dart_68] #3220671
03/15/24 05:29 PM
03/15/24 05:29 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
The 69 and down one, I don't like but the 1970 and up one I can't see there being a difference.
Re: Mopar Perf Racing Voltage Regulator [Re: B1MAXX] #3220672
03/15/24 05:44 PM
03/15/24 05:44 PM
Pennsylvania
Pennsylvania
Are you referring to the charging system, overall? Because I have a modern alternator (Toyo Land Cruiser), as well as other upgrades - wiring and stuff like that.
Re: Mopar Perf Racing Voltage Regulator [Re: 19_Dart_68] #3220691
03/15/24 07:40 PM
03/15/24 07:40 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Are you talking about the gold one with the heat sink?
Re: Mopar Perf Racing Voltage Regulator [Re: bobby66] #3220703
03/15/24 08:42 PM
03/15/24 08:42 PM
Pennsylvania
Pennsylvania
The constant output voltage regulator that puts out 13.5 volts all the time.
Voltage Regulator
Re: Mopar Perf Racing Voltage Regulator [Re: 19_Dart_68] #3220714
03/15/24 09:32 PM
03/15/24 09:32 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I don't know what the issue is supposed to be when using that particular regulator. It's the same one that was on my old 440 6-BBL Road Runner street car.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Mopar Perf Racing Voltage Regulator [Re: Brad_Haak] #3220717
03/15/24 09:45 PM
03/15/24 09:45 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The '70-up style VR was something Mopar recommended for their electronic (orange box) ignition conversions.
Ran one on my Hemi car for decades, no problem.
I've also just used the OEM '68-''69 VRs with Mopar electronic ignitions, and everything's working fine on those cars.
Re: Mopar Perf Racing Voltage Regulator [Re: 19_Dart_68] #3220726
03/15/24 10:21 PM
03/15/24 10:21 PM
Not designed for street use, drag race only was the original reason.
Probably based on higher amperage output for short times in the pits driving back after a run work scope
I buy and use a higher amp (100+ amps) output alternator now on my bracket cars up work
Re: Mopar Perf Racing Voltage Regulator [Re: Cab_Burge] #3220773
03/16/24 10:25 AM
03/16/24 10:25 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Mopar made both types in a race version, I'm not a big fan of the old mechanical style with one field wire. the newer version with 2 wires green and blue, would be fine electrically there can be no difference in its operation, so just a gimmic. Measure the voltage when running 14 something .....good.
he isn't talking the ignition control unit here.
Re: Mopar Perf Racing Voltage Regulator [Re: Cab_Burge] #3220818
03/16/24 01:54 PM
03/16/24 01:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted by Cab_Burge
Probably based on higher amperage output for short times in the pits driving back after a run.
Except the VR controls VOLTAGE not amperage. 13.5 volts is lower than the 14.2 I regularly see on my voltmeter with a factory VR.
Re: Mopar Perf Racing Voltage Regulator [Re: John_Kunkel] #3220833
03/16/24 02:23 PM
03/16/24 02:23 PM
Pennsylvania
Pennsylvania
That's a great point. Maybe the "not for street use" it is assuming that the 13.5 is not enough to keep lights and other accessories running at full potential on the street vs. the 13.5 being just to keep the ignition and a fuel pump powered.
Re: Mopar Perf Racing Voltage Regulator [Re: 19_Dart_68] #3220941
03/17/24 12:40 AM
03/17/24 12:40 AM
Boise
Moparteacher Offline
Boise
My guess is being set at 13.5V it doesn't have a ntc thermistor so no accomadation for hot or cold ambient/battery temperature like OEM-street regulators. 13.5V is on the lower end of the charging range with the norm being 13.2V-14.8V. A shorter battery life may also be the result. I would also suspect the non-variable charging point may be counter to optimum emissions requirements via torque load hence "Drag Race Only". But this is all speculation. RUN IT.
Re: Mopar Perf Racing Voltage Regulator [Re: Moparteacher] #3221039
03/17/24 02:09 PM
03/17/24 02:09 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
typically you'll see 14.2+ with the race one also, I'm telling you I think it was just a gimmick.
Re: Mopar Perf Racing Voltage Regulator [Re: B1MAXX] #3221119
03/17/24 07:04 PM
03/17/24 07:04 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
I have this voltage regulator on my Challenger. I have a high amperage alternator, fuel injection, and in-tank electric pump. I do a lot of street driving and the charging doesn't appear to be any different than anything else. I see about 14 volts off idle. I have link below to a video I just made showing the charging voltage after cold startup.
AG.
https://youtu.be/FORcUFekZbk?si=1G0jKpp9JMEEF30p
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Mopar Perf Racing Voltage Regulator [Re: 19_Dart_68] #3221222
03/18/24 01:02 PM
03/18/24 01:02 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It's Just a complaint-stopper statement.
Once in a great while, a customer would boil the battery. Usually they were in a warm climate area and driving the car every day, for long periods of time/street use.
It's really not fun to be blamed for wrecking someone's paint and to be screamed at "who is going to pay for this".
I never heard of anyone in metro Detroit with this issue.
Rich H.
Esse Quam Videri
