318/390 priming oil pressure 110 lbs #3220601
03/15/24 12:31 PM
03/15/24 12:31 PM
Nevada
merpar Offline OP
merpar  Offline OP
Nevada
I built a 318 stroker 390. Priming the oil system with drill on low rpm it has 110 lbs oil pressure. Am running 5-30 break in oil. Anyone know how much to cut off spring to lower pressure? All by bearing clearances are .0025.
Re: 318/390 priming oil pressure 110 lbs [Re: merpar] #3220605
03/15/24 12:34 PM
03/15/24 12:34 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I would get a new spring ...stock one...before cutting
Re: 318/390 priming oil pressure 110 lbs [Re: merpar] #3220611
03/15/24 12:41 PM
03/15/24 12:41 PM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
FYI,
on my 383 with a high volume pump, cold idle was 95 psi. Replaced spring with one from a standard pump, pressure cold was 55 psi
Re: 318/390 priming oil pressure 110 lbs [Re: varunner] #3220613
03/15/24 12:45 PM
03/15/24 12:45 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
What cup plug was used the hi press spring usually put out about 75.
The stock cup plug is very thin wall, If you use a standard 5/8 cup plug it usually pushes it up to 90.
Re: 318/390 priming oil pressure 110 lbs [Re: B1MAXX] #3220634
03/15/24 02:35 PM
03/15/24 02:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The pressure will drop down some after break in.
Re: 318/390 priming oil pressure 110 lbs [Re: B1MAXX] #3220705
03/15/24 08:50 PM
03/15/24 08:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
iagree
Re: 318/390 priming oil pressure 110 lbs [Re: merpar] #3220722
03/15/24 10:08 PM
03/15/24 10:08 PM
Pull the oil pump bypass valve out and make sure it has a small block valve in it (with several holes in the spring cup part) and not a BB type with no holes wrench scope
there was a bad batch of new Melling's or the other manufacturer years ago that had the wrong bypass valves in them whiney rant puke scope
Re: 318/390 priming oil pressure 110 lbs [Re: Cab_Burge] #3220854
03/16/24 04:42 PM
03/16/24 04:42 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Boy, I must have got one of those from Rock Auto, rebuilt a 340, started it on the run stand and it instantly pegged the pressure gauge, blew the seal from the oil filter and ballooned the Wix filter. Glad it was on the run stand and not in the car. It actually ruined my gauge as it would read 20 more PSI than it should have.
Re: 318/390 priming oil pressure 110 lbs [Re: GODSCOUNTRY340] #3220892
03/16/24 07:45 PM
03/16/24 07:45 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I would assume the bypass valve is stuck.
2011 Drag Pak Challenger
