Hemi Motor mounts versus motor plate car. Pros and cons?
#3220420
03/14/24 02:30 PM
03/14/24 02:30 PM
Posts: 7,495 Minnesota
Hemi_Joel
Minnesota
My son and are working on a land speed race car. We bought an existing car without an engine and are rebuilding it. Eventually it will end up with a vintage flathead Lincoln engine, but that engine won't be ready to race this year. So the plan for speed Week 2024 is to pull the 484-in Hemi out of my fast GTX and drop it into the land speed car temporarily. Then we can get out on the salt flats and get our rookie runs in and get our licenses. This is a rear engine modified roadster. The engine, transmission, and rear end all sit on a swing arm behind the driver, kind of like a motorcycle swingarm that is hinged on the frame, and has coil over shocks between the swing arm and the frame structure way out back. The swing arm is 2x4 steel tubing. So I need to decide if I should drop this Hemi in with a motor plate, or build some mounts that will go between the swingarm and the original Hemi block mounts. I've never ran a motor plate before. What issues would arise? Is it in the way of the oil pump and oil filter or any of that stuff? Since this is a one-year only deal, I want to keep it as simple as possible.
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Hemi Motor mounts versus motor plate car. Pros and cons?
[Re: AndyF]
#3220445
03/14/24 04:53 PM
03/14/24 04:53 PM
Hemi_Joel
Minnesota
The rails are pretty close to the engine block. So maybe using the stock mounting points on the block would be best.
[Re: Hemi_Joel]
#3220463
03/14/24 07:06 PM
03/14/24 07:06 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I have a front and mid- plate on my Hemi in my car. I have everything studed, so I can slide on the gasket, the front plate, the other gasket, then the water pump. All slides on in seconds. Also, simple to install and remove the engine out of the car easily by myself also.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Hemi_Joel]
#3222034
03/22/24 02:09 AM
03/22/24 02:09 AM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
I've ran plates in street cars before. I've got one now. I suggest fore/aft limiters, I put them in my street car. The engines aren't light!!
CrAzYMoPaRGuY
