Re: A-body Barracuda 340 notch
[Re: grancuda]
#3219437
03/09/24 11:31 PM
03/09/24 11:31 PM
Posts: 16,535 On the run…
BloFish
On the run…
I’m looking for a notch, and that looks nice, just not $35 nice.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3219581
03/10/24 05:25 PM
03/10/24 05:25 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
I’m looking for a notch, and that looks nice, just not $35 nice. I don't know why the title of this thread says 340. The original 273-4bbl was completely replaced by a 360 with a mild hot rod looking engine compartment. 68 and 69 340 Formulas sell for more money. Clean car though.
[Re: BloFish]
#3219634
03/10/24 10:47 PM
03/10/24 10:47 PM
Posts: 5,345 Planet Earth
RoadRunnerLuva
Planet Earth
Good looking Barracuda. Looks like Sand Pebble Beige paint. If not worth $35k to a couple people on here, then what is it worth to you?
Plymouth Makes It!
[Re: RoadRunnerLuva]
#3219715
03/11/24 11:58 AM
03/11/24 11:58 AM
autoxcuda
So Cal
Good looking Barracuda. Looks like Sand Pebble Beige paint. If not worth $35k to a couple people on here, then what is it worth to you? $20K to $25K. Barracuda coupes tend to sell for less than same year Darts. 67 least desirable of 3 years. Being a 273-4bbl HiPo Formula S helps. But the special motor stuff is all gone with this car.
[Re: autoxcuda]
#3219754
03/11/24 02:54 PM
03/11/24 02:54 PM
Posts: 5,479 Michigan
oldjonny
Don't argue with me.
Sorry to grab this thread, but while there are some A-Body guys here, just trying to figure out if I have the '67 insured for enough. I owned it for 43 years, before 'gifting' it to my daughter last fall. 53K miles (legit...based on how much I have driven it). 273 Commando auto car, no console, small rear end. Paint was done 43 years ago but has held up well. VERY minimal rear quarter patch panels (literally only couple inches) No other rust repair. I replaced front fenders back then with a pair from AZ just to get clean headlight sheet metal. I have all the original air cleaner as well (had to put a newer Carter on which had a throat that was too big for the factory air cleaner) Approximate insurance value? Thanks
Never, ever argue with an IDIOT. They will drag you to their level and then beat you with their years of experience
[Re: oldjonny]
#3219793
03/11/24 05:38 PM
03/11/24 05:38 PM
autoxcuda
So Cal
Sorry to grab this thread, but while there are some A-Body guys here, just trying to figure out if I have the '67 insured for enough. I owned it for 43 years, before 'gifting' it to my daughter last fall. 53K miles (legit...based on how much I have driven it). 273 Commando auto car, no console, small rear end. Paint was done 43 years ago but has held up well. VERY minimal rear quarter patch panels (literally only couple inches) No other rust repair. I replaced front fenders back then with a pair from AZ just to get clean headlight sheet metal. I have all the original air cleaner as well (had to put a newer Carter on which had a throat that was too big for the factory air cleaner) Approximate insurance value? Thanks Fastback Stock like engine compartment has slightly larger audience I think $5K to $10K more than this notchback and then additional $10K plus for insurance to replace quickly with classic car dealer price (retail)
[Re: autoxcuda]
#3219795
03/11/24 05:41 PM
03/11/24 05:41 PM
oldjonny
Sorry to grab this thread, but while there are some A-Body guys here, just trying to figure out if I have the '67 insured for enough. I owned it for 43 years, before 'gifting' it to my daughter last fall. 53K miles (legit...based on how much I have driven it). 273 Commando auto car, no console, small rear end. Paint was done 43 years ago but has held up well. VERY minimal rear quarter patch panels (literally only couple inches) No other rust repair. I replaced front fenders back then with a pair from AZ just to get clean headlight sheet metal. I have all the original air cleaner as well (had to put a newer Carter on which had a throat that was too big for the factory air cleaner) Approximate insurance value? Thanks Fastback Stock like engine compartment has slightly larger audience I think $5K to $10K more than this notchback and then additional $10K plus for insurance to replace quickly with classic car dealer price (retail) Really? So, like $30K-$35K'ish? Or are you saying more than that for insurance purposes?
[Re: oldjonny]
#3219964
03/12/24 01:08 PM
03/12/24 01:08 PM
autoxcuda
So Cal
Sorry to grab this thread, but while there are some A-Body guys here, just trying to figure out if I have the '67 insured for enough. I owned it for 43 years, before 'gifting' it to my daughter last fall. 53K miles (legit...based on how much I have driven it). 273 Commando auto car, no console, small rear end. Paint was done 43 years ago but has held up well. VERY minimal rear quarter patch panels (literally only couple inches) No other rust repair. I replaced front fenders back then with a pair from AZ just to get clean headlight sheet metal. I have all the original air cleaner as well (had to put a newer Carter on which had a throat that was too big for the factory air cleaner) Approximate insurance value? Thanks Fastback Stock like engine compartment has slightly larger audience I think $5K to $10K more than this notchback and then additional $10K plus for insurance to replace quickly with classic car dealer price (retail) Really? So, like $30K-$35K'ish? Or are you saying more than that for insurance purposes? I think it's worth $5K to $10K more than a same condition, option desirability notchback. At this 15-30K range. Not sure how your condition compares this particular notchback. But blue color paint is more desirable than cream. For insurance purposes, I would go an additional $5K-$10K more than typical private actual sale price. Meaning Classic Car Dealer amount "retail". Because you should have to hunt for a private seller to replace your car.
[Re: BigBlockGTS]
#3220413
03/14/24 01:57 PM
03/14/24 01:57 PM
RoadRunnerLuva
Planet Earth
I'd bet it sold for over $30K. It was very clean. You can't buy a mopar hot rod that nice for $25K Yes, of course you can. My Duster is for sale on this very website right now, for UNDER $25k.
Plymouth Makes It!
#3220495
03/14/24 09:46 PM
03/14/24 09:46 PM
Posts: 9,560 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
It does look like a nice A body. It would be hard for me to part with at that price. I'd bet it sold for over $30K. It was very clean. You can't buy a mopar hot rod that nice for $25K Yes, of course you can. My Duster is for sale on this very website right now, for UNDER $25k.
STOP POTATO HATE!
[Re: Mr PotatoHead]
#3220506
03/14/24 10:34 PM
03/14/24 10:34 PM
RoadRunnerLuva
Planet Earth
It does look like a nice A body. It would be hard for me to part with at that price. I'd bet it sold for over $30K. It was very clean. You can't buy a mopar hot rod that nice for $25K Yes, of course you can. My Duster is for sale on this very website right now, for UNDER $25k. Thanks for the compliment..potato head! It is hard to have it up for sale, but it's time to pass it on to another caretaker.
Plymouth Makes It!
[Re: BigBlockGTS]
#3220532
03/15/24 01:32 AM
03/15/24 01:32 AM
autoxcuda
So Cal
I'd bet it sold for over $30K. It was very clean. You can't buy a mopar hot rod that nice for $25K The 70 340 4spd swinger survivor sold and was asking $32K in the for sale section That’s $7K more car than a 67 Barracuda notchback 273 w/360 Roadrunnerluva’s 72 Duster seems at least as desirable than this Barracuda.
