Dana 60’s from Ford e350 worth building? #3217247
03/01/24 12:16 PM
03/01/24 12:16 PM
SINY
SanityLost Offline OP
SINY
Have the option of getting a Dana 60 that is in a Ford E350 Van. There’s actually 3 , 2 2009 Vans and one 2012.
Are these worth getting and have them cut and built to fit a car of choice?
Re: Dana 60’s from Ford e350 worth building? [Re: SanityLost] #3217261
03/01/24 01:02 PM
03/01/24 01:02 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Price a new S60 bare housing and compare against the core + labor.
Also give some thought about whether you care about the lack of snubber provisions and very slightly greater complexity of service (compared to an S60 with diff bearing adjusters) on truck housings.
I'd done that a few years ago and at the time I think there was a small savings going with a salvage yard piece, but it
may have been worth it to pay lightly extra and not have to do any of the work, and have a shiny housing with no grease or rust to deal with, nothing to cut, just build it.
Rich H.
Esse Quam Videri
Re: Dana 60’s from Ford e350 worth building? [Re: ZIPPY] #3217263
03/01/24 01:08 PM
03/01/24 01:08 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Mine came out of a 1 ton duallie Dodge.
We cut off the full floater ends and replaced with ends I had from an old 8 3/4 housing. I also installed Dr. Diff axles and spool.
With a gear change and some labor to the local chassis shop to burn the ends on, I had around $900.00 in it.
'63 Dodge 330
11.19 @ 121 mph
Re: Dana 60’s from Ford e350 worth building? [Re: GY3] #3217282
03/01/24 01:55 PM
03/01/24 01:55 PM
moparx Offline
moparx  Offline
if you can do the work yourself, [or con a buddy to do it for you with beer for payment] and have the setup bar and bearing alignment plugs, it could very well be worth it.
however, if you don't possess the know-how or tools to do the job, it wold be cost effective to just buy the rear done to your specs.
then there is the "time value cost" to consider. how much is your time "worth" ?
beer
Re: Dana 60’s from Ford e350 worth building? [Re: moparx] #3217301
03/01/24 03:52 PM
03/01/24 03:52 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I used a 1 ton truck axle for mine. The tubes are thicker to begin with for a race car application such as mine. As mentioned above. I cut the full floating truck ends off and we welded on new Strange Engineering ends. I also have Strange gun drilled 40 spline light weight axles and light spool, with a 4:10 Pro Gear, with the low profile calipers to clear for dbl beadlocks, with Strange rotors and 5/8" studs. I have less than $1700.00 into everything.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Dana 60’s from Ford e350 worth building? [Re: SanityLost] #3217309
03/01/24 04:44 PM
03/01/24 04:44 PM
If my memory is correct ford offered two different Dana 60 H.D. axle tube diameter, 3.0 and 3.250, maybe even a 3.125 width earlier scope
I've used all three, I prefer the 3.0 or the 3.125 for the weight savings up
The shorter , narrower axle tubes, the less weight up grin
Re: Dana 60’s from Ford e350 worth building? [Re: Cab_Burge] #3217360
03/01/24 08:27 PM
03/01/24 08:27 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Some of those E van axles were C clip semi floating style. On those it might be practical to have the shafts shortened, resplined and drilled for the right lug patterns.
Angry white pureblood male
Re: Dana 60’s from Ford e350 worth building? [Re: ruderunner] #3217384
03/02/24 01:17 AM
03/02/24 01:17 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Both Dizusters and mine are out of Ford trucks. New ends, spool, axles, gear. We do it ourselves. Even ran the junkyard gears in one. Mine was free. As I remember his was either free or cheap as well.
Doug
Re: Dana 60’s from Ford e350 worth building? [Re: Cab_Burge] #3217666
03/03/24 10:29 AM
03/03/24 10:29 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I retrieved a "Dana 60" from a Diesel E350, and discovered it was actually a Dana 70, doable, but not ideal.
Re: Dana 60’s from Ford e350 worth building? [Re: ruderunner] #3217699
03/03/24 12:20 PM
03/03/24 12:20 PM
Alberta
rustbuckett68 Offline
Alberta
64-72 F-100 pickups had an optional Dana/Spicer 60 Powerloc diff when the buyer wanted a locking diff. 5 bolt axles (5 on 5 1/2").
Usually came with 3:54 gears (mine does in my 66 F100), but I have had 4:10 sets, and I did see a rate plate /6, 4 speed 4:88.
Guessing farm truck. Think 3" tubes. Can't remember the overall width or spring mount (they were on top). Narrower than a square body gm.
Re: Dana 60’s from Ford e350 worth building? [Re: ZIPPY] #3217702
03/03/24 12:42 PM
03/03/24 12:42 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
When I was hunting around for 60's and 70's for my project,pretty much all of used truck rears had spun a carrier bearing and the housing surfaces were worn. It needs the carrier pulled to see the wear of course. I ended up taking the
housings to a machine shop with a line boring tool and they cut the bearing lands flat again, cost about 400.00.
Re: Dana 60’s from Ford e350 worth building? [Re: Uberpube] #3217968
03/04/24 11:13 AM
03/04/24 11:13 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Must have lucked out. I found a D60 on Craig's List that was a pull out of an '80 F250 for $100. Had a local shop cut it to size and bought all the parts from Dr. Diff. I think I reused the ring gear.
Re: Dana 60’s from Ford e350 worth building? [Re: SanityLost] #3219016
03/08/24 12:41 AM
03/08/24 12:41 AM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
I used a Ford Dan60 in my old 1965 plymouth B body
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Dana 60’s from Ford e350 worth building? [Re: SanityLost] #3219148
03/08/24 07:05 PM
03/08/24 07:05 PM
if your going to drag race it in a car with clutch or trans brake I would replace the driver side stock carrier cap with a steel one from either Malk Williams or Strange Engineering twocents scope wrench up
Re: Dana 60’s from Ford e350 worth building? [Re: Cab_Burge] #3219837
03/11/24 09:21 PM
03/11/24 09:21 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
I just bought a Dodge truck D60 with 4.10's in it from a guy in Southern Indiana for $100. I'm happy to see this post in here today.
eBay-cdwmotorsports
Re: Dana 60’s from Ford e350 worth building? [Re: cdwmotorsports] #3219864
03/11/24 11:58 PM
03/11/24 11:58 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Give Dr. Diff a look for parts. Very happy with mine!
'63 Dodge 330
11.19 @ 121 mph
Re: Dana 60’s from Ford e350 worth building? [Re: GY3] #3219907
03/12/24 09:00 AM
03/12/24 09:00 AM
an8sec70cuda Offline
iagree I did two of them at the same time. I have a friend that narrowed them for free, then I did the gear setup and all assembly myself.
Got lucky w/ one of them that it already had the good powerlock diff., 3.54 gear, and a 1350 yoke on it. Only needed narrowing w/ new housing ends, axles, and a 35 spline gear kit for the diff.
All parts from Dr. Diff. up
Like mentioned previously....most will have thicker axle tubes (3.25" versus 3" if I recall correctly) so you'll need larger U bolts. I got the bigger U bolts from NAPA.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dana 60’s from Ford e350 worth building? [Re: an8sec70cuda] #3219970
03/12/24 01:34 PM
03/12/24 01:34 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted by an8sec70cuda
[quote=GY3]
Mine had the thicker axles, I did manage to get stock u-bolts around them, though. Definitely 3.25".
'63 Dodge 330
11.19 @ 121 mph
Re: Dana 60’s from Ford e350 worth building? [Re: GY3] #3220348
03/14/24 08:46 AM
03/14/24 08:46 AM
[quote=GY3]
Yep, you can force them and bend them to fit, but the right ones fit so much better. I did the same thing, lol.
CHIP
Re: Dana 60’s from Ford e350 worth building? [Re: an8sec70cuda] #3220516
03/14/24 11:19 PM
03/14/24 11:19 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I have narrowed 6 or 7 truck Dana's over the years. the 60's 1/2 ton Ford ones I have tried to use were bent so badly, that i quit getting them, not sure if they were that much lighter, or just badly abused farm trucks. Have had good luck with the 3/4 ton Dodge and Ford rears. And as mentioned Dr Diff has all the parts. I usually just use 8 3/4 ends unless somebody requests otherwise. The S-60's adjusters are real nice if you do not have the pullers and spreaders, but definatley cheaper to go the truck route. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
