washer jar fasteners #3219785
03/11/24 05:05 PM
03/11/24 05:05 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I am putting my windshield washer squirters and the washer Jar back in my 72 demon. does anyone know the size of the fasteners used to hold the washer jar in place. year one wants 10 bucks for 2 wood screws. My plan would be to get Stainless steel wood screws of the same size but i can't find anything size info on them.
thank you in advance.
Thank you
Kiddart
Re: washer jar fasteners [Re: Kiddart] #3219798
03/11/24 05:53 PM
03/11/24 05:53 PM
MD
floyd Offline
floyd  Offline
MD
I’m not too familiar with A-body but these are correct for E/B-body. Only negative is the $30 minimum order from AMK.
https://www.amkproducts.com/bulk-fasteners-products/?Product_ID=13734
Re: washer jar fasteners [Re: floyd] #3219803
03/11/24 06:21 PM
03/11/24 06:21 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: washer jar fasteners [Re: mopars4ever] #3219813
03/11/24 07:54 PM
03/11/24 07:54 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
The DMT ones.
#8 with captive washers for the plastic jar.
Re: washer jar fasteners [Re: topside] #3219825
03/11/24 08:32 PM
03/11/24 08:32 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Same screw used inside the console to mount it.
Fuel filler to trunk floor seals
If you want close enough.
Hit homedepot and get some #10 x 5/8" ( Or a 3.4" length ) screws and small washers
Re: washer jar fasteners [Re: topside] #3219845
03/11/24 10:12 PM
03/11/24 10:12 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Thank you. I will go to DMT tomorrow and pick them up
Thank you again
Thank you
Kiddart
