Re: For Sale - Race Parts - 1st Quarter
[Re: moparts]
#3213292
02/13/24 07:32 PM
02/13/24 07:32 PM
Posts: 5,894 Florida
Locomotion
MAIN BEARINGSSpeed Pro 120 M Std. - 360 Main Bearings (¾ groove) - (2 available) - $55.00/ea. set Speed Pro 120 M 10 - 360 Main Bearings (¾ groove) - $55.00/ea. set [ Clevite - MS1051P 10 – 360 Main Bearings (½ groove) - $70.00/ea. set ROD BEARINGS -Sealed Power/Federal Mogul 8-2130CP .030 rod bearings (not in original box) - $35,00/set of 8 Sealed Power/Federal Mogul 8-2130CP .030 rod bearings - $40.00/set of 8 Sealed Power/Federal Mogul 8-2130CP .020 rod bearings - $45.00/set of 8 PISTON RINGS -Childs & Albert RS-10477 – 25 4.025 5/64 file fit low tension oil rings - $80.00 set Childs & Albert RS-10477 – 45 4.045 5/64 file fit low tension oil rings - $80.00 set Hastings 2M 5505 035 – 4.035 1/16 file-fit low tension oil rings - $70.00 set TIMING CHAINS -Cloyes True Roller 9-3103 Timing Chain Set - $50,00/set *****SALE PENDING*****Cloyes True Roller 9-3103-5 (.005 short) Timing Chain Set – $70.00/set Cloyes 9-135 Std. replacement True Roller timing chain only - (2 available) - $45.00 ea. C loyes 9-135-5 (.005 short) replacement True Roller timing chain only - (2 available) - $55.00 ea. MISC. -Ross 984-01-25 Wrist Pins, Type 1, .984 in. Diameter, 2.500 in. Length, .150 in. Wall, 125 Grams - $100.00/set of 8 Eagle 12055 3/8" SIR rod bolts (also fits several Chevy, Ford, 3/8" SIR rods) - (2 available) - $100.00 ea. set All prices + shipping.
Shipped from Florida 32117
locomo@bellsouth.net
Sorry, no PayPal.
USPS money orders welcome.
[Re: moparts]
#3214355
02/18/24 02:23 PM
02/18/24 02:23 PM
Posts: 148 Albert Lea, MN
GTX5877
Albert Lea, MN
Used Edelbrock 2920 Victor W-2 "Square Port" Intake for SB Mopar. Threaded holes in good shape, includes water lines, water outlet and cool MOON temp gauge that Doesn't work.
$250 + the ride
1967 Dart GTS 426 Gen III Hemi 1968 Hemi Cuda 572 SS/AH Clone 1988 Chrysler LeBaron Coupe S/S 2003 Dodge Ram 1500 4dr SLT lowered 2012 Ram 1500 2wd Lowered 1970-1/2 Camaro Z-28 1974 VW Karman-Ghia
[Re: moparts]
#3214394
02/18/24 04:48 PM
02/18/24 04:48 PM
GTX5877
Albert Lea, MN
Used Ladder bar Brackets (4) $15
Used adjustable shock brackets $25
Used Low rise aluminum Velocity stack $20 *********SOLD************
Used Mopar 8-3/4" yoke for 7260 U-joint, fine spline 29, threading good $25
Used Mopar 8-3/4" yoke for 7290 U-joint, fine spline 29, threaded holes good. $35
New TCI 5.0 band apply lever 727 & 904 $20
(2) used Transdapt remote oil filter mount with (2) #10AN fittings. Sorry, both are for GM 13/16" nipple . $25 each
All parts plus shipping. More pix available of individual items.
PM or email GTX5877@yahoo.com.
SOLD 383 Weiand Tunnel Ram w (2) 4224 Center Squirters
[Re: Rocket]
#3215562
02/23/24 10:28 AM
02/23/24 10:28 AM
Posts: 1,548 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Nice Vintage Tunnel Ram for 383-400 with pair of matched 4224 center squirters. appears uncut original.
Also comes with linkage and fuel line as pictured. Ran it a few years back on a run-in stand and all worked well.
SOLD can deliver to Indy.
Chris
[Re: moparts]
#3216024
02/25/24 12:22 PM
02/25/24 12:22 PM
GTX5877
Albert Lea, MN
Retirement sale continues: Have several small parts:
Set of 16 Titanium 10 degree valve spring retainers. 1.44" OD x 1.067" step x .705" inner step for dual or single spring $50 for set
340 Dampner with timing tape, cast #3614369 $25
C & S Specialties ultra light alcohol fuel filter, plastic with stainless screen, cleanable. $25
Mopar 8-3/4 or Dana 60 axle retainers for "Green" type ball bearings 2 pair $10/pair
Traction bar square u-bolts for in front or behind rear axle $5
NEW Victor JV605 for 360, which is misboxed, should be JV606 for 318-340 $8
All parts plus shipping from 56007
[Re: GTX5877]
#3216028
02/25/24 12:40 PM
02/25/24 12:40 PM
GTX5877
Albert Lea, MN
MORE ITEMS:
Mr Gasket #6230 radiator hose T-Clamps. NEW in the package. Discontinued from MrG. $15 ***********SOLD********
NEW Speed- Pro R9278-35 file fit rings for 440 +.030, 4.350" bore, low tension oil, 1/16 x 1/16 x 3/16". New price today is $140, will take $60! ********SOLD***********
Melling K-63 Big block oil pump repair kit less pump gears. Has bypass springs and valve + gaskets $5
Hemi lash caps are *********SOLD***********
NEW Moroso 85820 U-Joint Girdles for 8-3/4 with 7290 yoke $25
All items plus shipping
[Re: fbs63]
#3218336
03/05/24 02:34 PM
03/05/24 02:34 PM
Posts: 1,838 NW Indiana
fbs63
NW Indiana
Ptc 10" 727 converter. Set up for BB with a big single,twin turbos or blower. Billet front half. Steel stator High HP capable. $700 obo. PM me here. Located in NW Indiana.
update
[Re: fbs63]
#3218889
03/07/24 04:48 PM
03/07/24 04:48 PM
Posts: 136 ca
Swingin70
ca
update
K&R Pro Cube Delay Box
[Re: Swingin70]
#3218906
03/07/24 06:05 PM
03/07/24 06:05 PM
Posts: 342 Indiana
Gabby63
Indiana
I am selling my K&R Pro Cube Delay Box , in great condition , operates as it should , 325.00 - OBO - Also if needed I have the 3D printed removable mount for 90.00 more .
Items are plus shipping .
Gary
Sold!
[Re: Gabby63]
#3219067
03/08/24 11:14 AM
03/08/24 11:14 AM
fbs63
NW Indiana
CSU Gas Blow Through Dominator. New, never had fuel in it. Dual needle and seat float bowls, dual boost referenced power valves, annular boosters. Perfect for pump or race gas set up. Including billet E85 metering plates for conversion. Recommend sending to CSU for complete E85 conversion if desired. Have pics of internals if needed. $1000 shipped Comparable carbs are $2500 now. PM here. Located in NW Indiana. SOLD!
Holley 1 to 1 Linkage Kit - NEW
[Re: moparts]
#3219649
03/11/24 01:17 AM
03/11/24 01:17 AM
GTX5877
Albert Lea, MN
New Holley 20-3 Throttle shaft kit conversion to 1 to 1 linkage ratio. Holley 4150 1-11/16" throttle plate.
Comes with primary and secondary shafts and plate screws. Open box.
Summit $83.35.
Sell for $50 shipped to continental US.
Sheetmetal Valve Covers SB Mopar
[Re: moparts]
#3219651
03/11/24 01:34 AM
03/11/24 01:34 AM
GTX5877
Albert Lea, MN
Unique brand fabricated aluminum valve covers for Small Block Mopar. Originally made in Iowa.
Early design with thin rails which were needed for W2 rocker and pushrod clearance.
Brushed finish with 1 hole per cover. Comes with long allen bolts.
These were about $275 when new, Sell for $90 + shipping
