Expensive mistake #3219157
03/08/24 08:37 PM
03/08/24 08:37 PM
AndyF Offline OP
AndyF  Offline OP
Have a 427 Chevy on the dyno at the moment. It is a 1966 four bolt casting, originally from a Corvette according to the guy who owns it. Unfortunately, the original owner was so paranoid about someone stealing his 427 that he stamped his name and driver license number over the factory numbers and ruined the value of the block. These early Corvette blocks sell for up to $10,000 to a collector.
Since it isn't a numbers block anymore the current owner hot rodded it. Stroked it to 496, added Trick Flow heads and a solid street roller cam. It is a nice engine, makes 630 hp and 615 torque. Going in an El Camino. Should be a blast.
Re: Expensive mistake [Re: AndyF] #3219160
03/08/24 08:53 PM
03/08/24 08:53 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
If you don't care about numbers, it's not a mistake!
'63 Dodge 330
11.19 @ 121 mph
Re: Expensive mistake [Re: GY3] #3219173
03/08/24 09:50 PM
03/08/24 09:50 PM
AndyF Offline OP
AndyF  Offline OP
Here is another very similar engine that is in the shop at the moment. This is another 1966 427 but the factory engine numbers are still on it so it can be decoded as a 1966 427/425 or a L72. The 427/425 had solid lifters, 780 Holley carb, a bunch of special parts and only came with a manual trans. This one came out of a passenger car but the VIN isn't stamped on it so don't know what. Probably Impala SS. The passenger car 427/425 are much rarer than the Corvette L72 engines since most people buying a big car didn't want a high compression, solid lifter engine with a manual shifter.
I think this one his getting hot rodded too but I don't know the details.
Re: Expensive mistake [Re: GY3] #3219227
03/09/24 03:03 AM
03/09/24 03:03 AM
iagree up
it is only a mistake if the owner of the parts think it is, correct Andy work shruggy
Re: Expensive mistake [Re: AndyF] #3219228
03/09/24 03:59 AM
03/09/24 03:59 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
It's not as much of a mistake as the guy who ground off the VIN number of a 1970 426 Hemi out of a 70 Hemi Challenger Convertible so he could stamp in the VIN number for his 66 Hemi Satellite. laugh2
Re: Expensive mistake [Re: SNK-EYZ] #3219230
03/09/24 06:54 AM
03/09/24 06:54 AM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
I thought VIN numbered blocks didn’t begin till 68, so a correctly dated 66 block could be called a numbers engine?
Re: Expensive mistake [Re: Pacnorthcuda] #3219236
03/09/24 08:20 AM
03/09/24 08:20 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Corvette guy's don't care about the numbers on the block originally, they put them on during "restoration "
Angry white pureblood male
Re: Expensive mistake [Re: Pacnorthcuda] #3219237
03/09/24 08:20 AM
03/09/24 08:20 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Exactly, but a 1969 casting date block that you ground off the VIN that started JS27R0B would never be correct, but the guy did it. whistling
The VIN pad on the oil plan rail didn't even exist on Hemi blocks (or big blocks) till 68.
Re: Expensive mistake [Re: SNK-EYZ] #3219243
03/09/24 08:57 AM
03/09/24 08:57 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
THATS what a mistake looks like laugh2
Re: Expensive mistake [Re: AndyF] #3219256
03/09/24 10:29 AM
03/09/24 10:29 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Wouldn't decking the block take the numbers off?
Re: Expensive mistake [Re: justinp61] #3219273
03/09/24 12:36 PM
03/09/24 12:36 PM
AndyF Offline OP
AndyF  Offline OP
Yep, that is a big problem with the high dollar Chevy blocks. Lots of blocks lost their VIN numbers during rebuilds back in the 70's and 80's. Eventually people figured out to leave the VIN area unmachined but that requires modern equipment. The old surfacing equipment used 40 years ago just did a complete pass and the VIN number and engine ID was destroyed.
Re: Expensive mistake [Re: AndyF] #3219275
03/09/24 12:40 PM
03/09/24 12:40 PM
central il.
second 70 Offline
second 70  Offline
central il.
If that block was installed in a car it would have the serial number on the pad. They started on corvettes in 1960
Re: Expensive mistake [Re: second 70] #3219297
03/09/24 02:05 PM
03/09/24 02:05 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Well, stamping Corvette blocks - or should I say re-stamping - to have the desired #s has been going on forever.
Obviously, that usually requires decking, but it's been a refined art for some time...
Re: Expensive mistake [Re: second 70] #3219335
03/09/24 04:20 PM
03/09/24 04:20 PM
AndyF Offline OP
AndyF  Offline OP
Yeah I've seen some mention of that. Sounds like GM only stamped the VIN on special combinations and even a 427/425 Impala SS wasn't special enough to get a VIN stamp in '66. Without a VIN we're just guessing on the Impala SS. Could also be a Biscayne. No way to know at this point but it was a rare bird whatever it was.
Re: Expensive mistake [Re: AndyF] #3219377
03/09/24 06:42 PM
03/09/24 06:42 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Well their first mistake was building a Chevy......Todd
Re: Expensive mistake [Re: sasquatch] #3219387
03/09/24 07:17 PM
03/09/24 07:17 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
laugh2
'63 Dodge 330
11.19 @ 121 mph
Re: Expensive mistake [Re: topside] #3219391
03/09/24 07:53 PM
03/09/24 07:53 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
As has restamping Mopar blocks.................
Re: Expensive mistake [Re: sasquatch] #3219424
03/09/24 10:31 PM
03/09/24 10:31 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
iagree drive
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Expensive mistake [Re: metallicareload] #3219465
03/10/24 09:07 AM
03/10/24 09:07 AM
PA
moparacer Offline
moparacer  Offline
PA
That was not a mistake, that was owner stupidity.
I have seen it done to very collectable guns too.
The good thing about a block is it can be machined and corrected, whereas you don't mess with gun serials.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Expensive mistake [Re: moparacer] #3219490
03/10/24 11:52 AM
03/10/24 11:52 AM
Central NC
gch Offline
gch  Offline
Central NC
With those heads and a solid roller cam I would have expected more hp ? Don't know the rest of the specs but 600hp in any street car should be a plenty.
